Hey guys, I was just wondering if anybody knew where I could find a set of 1.5" wheel spacers that have the lip on them for hub-centric steel dually rims? I'm putting them on a full float Dana 60 that came out of a single rear wheel E-350 van. When I went to see if the dually rims fit, they bottomed out on the brake drum before they sat on the hub, so I need a spacer about 1.25 to 1.5" thick. (Or if it is even possible, seen as though the hubs don't have a very steep taper to them, so the lip would be pretty thin.) Thanks for any help...
And it may be difficult to find. Manufacturers would be very hesitant to have one of their spacers put on a dually applications - because duellies usually end up with serious loads, and spacers are not such a good idea with heavy loads.
