Sponsored by: Real Truck
Replacing airbag clock spring?
Old Jan 2, 2008 | 07:04 AM
viperbluelx's Avatar
viperbluelx
I'm getting a code 32 which I believe to be airbag clock spring. How hard is this to replace and what's involved? Is it under the airbag or do I have to pull the steering wheel too?
Old Jan 5, 2008 | 08:29 PM
viperbluelx
nobody can help me out?
Old Jan 5, 2008 | 10:26 PM
F350-6's Avatar
F350-6
I can send you instructions but you'll have to wait until Monday since I left my service DVD at work. It seems like it's about 12 pages long so I'll get your email address and send it to you then if no one else helps you. If I happen to forget send me a PM on Monday.
Old Jan 5, 2008 | 10:27 PM
Hootbro's Avatar
Hootbro
http://www.angelfire.com/tx/hootbro/Clockspring.pdf
I would check the connection and reseat them first. The clockspring is usually hard to find broken.
Old Jan 5, 2008 | 10:46 PM
viperbluelx
Really? I was always told the clockspring was the main cause of an airbag light. Anyway, I guess I can check the connection without even pulling the steering wheel, right?
Old Jan 5, 2008 | 11:10 PM
Hootbro's Avatar
Hootbro
I am just suggesting check what can be the obvious. In my experience, many electrical/electronic type failures are due to installation errors rather than component failures.
I had a like issue on my 2004 Ranger and it was a loose connection
The clock spring is just a glorified ribbon cable circuit riding on coiled spring. Not really alot to break but I guess anything is possible. Cheaper to check connections before ordering a part you might not be able to return.
Hootbro
Old Jan 5, 2008 | 11:15 PM
F350-6's Avatar
F350-6
Hootbro
I agree it's worth checking. I was ready to replace mine since my cruise control started acting funny. I checked all the wires inside the steering column for shorts before I tore into it. I never found a short but my cruise has worked ever since I wiggled all those wires around.
Old Jan 5, 2008 | 11:34 PM
Rongold's Avatar
Rongold
Clockspring
The wheel must be removed to replace the clockspring.
RON
Old Sep 10, 2008 | 06:09 PM
RDCampbell's Avatar
RDCampbell
Need Help
When I trun Left, my horn blows. not kidding!
I do have an Airbag Code 32, How does this effect the horn?
Thanks
2003 F450 SD
Old Sep 10, 2008 | 07:17 PM
2002 F350V10's Avatar
2002 F350V10
I have done it, and the job takes about 1-1 1/2 hours to do. Disconnect battery, wait 15 minutes, and then remove airbag, steering wheel, lower steering cover, ignition lock cylinder, and steering column upper and lower shrouds. Disconnect wiring for the clockspring, unclip the assembly, and remove. Piece of cake and actually very easy.
all4ford
Oct 9, 2019 05:57 PM
kevinshin
1983 - 2012 Ranger & B-Series
Mar 24, 2016 12:33 PM
jordan1996
Jun 17, 2015 08:31 PM
Quackhead94ranger
May 25, 2004 09:20 PM
