ac heater control problem
Old Sep 9, 2008 | 07:35 PM
357fhp's Avatar
357fhp
Red face ac heater control problem
Hi all
I need to pick somebody's brain. my 350 has been sitting for a month or two and today the control for the ac , heater ,defrost wont change. the air conditioning blows thru the defrosters and i cant change it to the dash or the feet or to max what gives ? thanks in advance for all your valuable help
randy 357fhp
Old Sep 9, 2008 | 07:50 PM
megawatt00's Avatar
megawatt00
You have a vacuume leak. When this happens it defaults to defrost.
Old Sep 9, 2008 | 08:06 PM
zx250's Avatar
zx250
Of the next Riffraff East
Jim's right, you have a vacuum leak or you vacuum pump is not working at all. Make sure you pump is working, if you have 4 wheel drive, unplug the line coming out of the soleniod and plug, check again. If that fixes the problem, the leak is in th ESOF system.
Old Sep 9, 2008 | 08:50 PM
greagin's Avatar
greagin
yep, you may need to replace the vacuum lines that run to your hubs
Old Sep 9, 2008 | 09:31 PM
357fhp's Avatar
357fhp
thanks guys'
forgot to tell you its a 2 wheel drive BUT i went out started it and moved it into my driveway, took a small hammer tapped the air pump a couple of times and it is working like a new one perfectly. thank you !!!!!!!!!!!!
Old Sep 9, 2008 | 09:51 PM
megawatt00's Avatar
megawatt00
Sometimes all it takes is a BFH or a SAH. Keep an eye on it. She seized for a reason, you may want to consider replacing it.
357fhp
13
Dec 13, 2006 12:21 AM
357fhp
Nov 27, 2006 08:28 AM
357fhp
Nov 24, 2006 06:22 PM
357fhp
Nov 12, 2006 11:59 AM
