Acronym's list
Old Nov 26, 2006 | 11:17 AM
357fhp's Avatar
357fhp
Smile Acronym's list
Hi Yuall
Where do I find this list ?
Old Nov 26, 2006 | 12:07 PM
wlihntr's Avatar
wlihntr
like this:
Acronyms - Ford-Diesel Abbreviations
2x4 =Two Wheel Drive
4L100 =Automatic Transmission 4 Super Duty Trucks
4x4 =Four Wheel Drive
ABS =Anti-Lock Braking System
AC =Air Conditioning
AIC =Auxiliary Idle Control
APCM =Auxiliary Power train Control Module
ATF =Automatic Transmission Fluid
BARO =Barometric Pressure Sensor
BB =Bulletin Board
BBS =Bulletin Board System
BCA =2nd Best Bearing Company
BTW =By the way
CC =Crew Cab (4 door)
CDR =Crankcase Depression Regulator
CPS =Cam Positioning Sensor
DORA =Dealer Order Receipt Acknowledgment
DRW =Dual Rear Wheels
DTC =Diagnostic Trouble Code
DVOM =Digital Volt-Ohm Meter
E4OD =Auto Transmission on Pre-'99 Ford Pickups
EEC =Electronic Engine Control
EGT =Exhaust Gas Temperature
EOT =Engine Oil Temperature
FAQs =Frequently Asked Questions
GM =General Motors
GP =Glow Plug
GPR =Glow Plug Relay
GVWR =Gross Vehicle Weight Rating
HEUI =Hydraulic Actuated Electronic Controlled Unit Injector
IAT =Intake Air Temperature Sensor
IDM =Injector Drive Module
IMHO =In My Humble Opinion
LB =Long Bed
LOL =Laugh Out Loud
MAF =Mass Air Flow Sensor
MAP =Manifold Absolute Pressure Sensor
OD =Over Drive
OEM =Original Equipment Manufacturer
OTC =Owatonna Tool and Equipment Company
PCM =Power train Control Module
PCV =Positive Crankcase Ventilation
PDL =Power Door Locks
PM =Power Mirrors
PS =Power Stroke
PSD =Power Stroke Diesel
PTO =Power Take Off (winch)
PTTTM =Power Telescoping Trailer Tow Mirrors
PW =Power Windows
PWM =Power Window Motor
RC =Regular Cab
SB =Short Bed
SC =Super Cab (extended cab)
SRW =Single Rear Wheel
TC =Torque Converter or Transfer Case
TPS =Throttle Position Sensor
TSB =Technical Service Bulletin
TTM =Turbo Temp Monitor
VAC =Volts Alternating Current
VDC =Volts Direct Current
VECI =Volts Direct Current
WOT =Wide Open Throttle
Old Nov 26, 2006 | 01:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I'll give the credit. http://pages.prodigy.net/stevebaz/_i...az/index3.html
Scroll on down more, there's lots of neato stuff.
Old Nov 27, 2006 | 08:28 AM
Smokin''s Avatar
Smokin'
Smokin
Did anyone notice that HPOP (high pressure oil pump) is not on your neato little list here?
I only say because that's one of the big ones I didnt recognize when I joined FTE.
pagoda69
Jun 11, 2012 07:12 PM
Vinford
British Columbia
Oct 14, 2010 04:00 AM
gopher18
Chapter Meets Planning
33
Aug 5, 2005 08:29 PM
karljay
Oct 12, 2002 02:14 AM
StockMan
Sep 5, 2001 08:39 AM
