ICP Sensor replacement cost?
Old Sep 30, 2010 | 04:55 PM
firemanrob's Avatar
firemanrob
my problem is intermitant. dealer says good fuel pressure and no codes are given. idle surges at times then drops. little hesitation on excelleration when problem is happening. dealer says there are 2 sensors. 1 at top fuel filter 2 at side of moter. any ideas which one is going bad
Old Sep 30, 2010 | 06:09 PM
firemanrob's Avatar
firemanrob
have 6.0 2006. i have idle surge then drops down. problem is intermitant.dealer says good fuel pressure with no codes given. they say there are 2 pressure sensors.1 at top fuel filter other icp at side of motor.any ideas on trouble shooting which one or the pigtail only.
Old Sep 30, 2010 | 06:23 PM
amgpro2's Avatar
amgpro2
If it is the new updated part then the connector on the sensor is different and will require the updated pig tale. IRC the old connector is a 2wire while the new one is a 3 wire.
Old Sep 30, 2010 | 06:29 PM
wulfman's Avatar
wulfman
I have an 03 got same code dealer wanted 700 did not drive for 2 weeks, while reseaching problem found this site by accidend started reading went to tech folder and it shows how to get it from the top its not that hard to do its even got pics try it dont give dealer your money
Old Sep 30, 2010 | 08:12 PM
sandmanf250's Avatar
sandmanf250
icp
got my sensor on e-bay for 45.00 spent 2and a half hours doing from the the top.used electricl contact cleaner to clean out the pigtail stuck her back together and she's running great.
Old Mar 18, 2011 | 03:13 PM
mikendale's Avatar
mikendale
I was charged about 800.00 from a dealer in Mississippi. Truck broke down and had to have it towed there. I was from out of town and at their mercy. should it be covered under warranty? I have 96K miles.
Old Mar 18, 2011 | 04:15 PM
nylyon's Avatar
nylyon
I did mine for $50. Got the sensor off of eBay used the original wiring haven't had a problem. It took me about 2 hours, most of the time was spent scratching my head. If I had to do it again, it would probably take 30 minutes. I got to it from the bottom.
Old Mar 18, 2011 | 04:33 PM
ljutic ss's Avatar
ljutic ss
My 03 ICP was replaced in 04, Ford paid the dealer 50 minutes time to do the job.
Old Mar 18, 2011 | 05:32 PM
Piolet's Avatar
Piolet
Have them give you a full break down of the charges.
Materials ... part numbers and cost.
Labor ... how many hours and how much $$ per hour.
$800 is crazy, but was it for other work too? Did you pay for the tow?
Old Mar 18, 2011 | 08:25 PM
kidoo's Avatar
kidoo
Had mine done on the engine 5 year waranty, 100 dollars deductible, they changed the pig tail also. Mine had an intermitent surging at iddle and between 1500 an 1700 RPM, it did not fixed the problem. I had the IPR changed today, it seem to have fixed the problem, so far so good, 100 highway miles, slide camper and trailer. Will see if problems come back.
Old Mar 20, 2011 | 02:26 PM
HeavyTow's Avatar
HeavyTow
If you don't mind please post or send me a pm as to what town or dealership you dealt with. I live in Miss and don't want to get taken by that dealership for sure.
Old Jan 6, 2012 | 11:14 AM
Jeanp's Avatar
Jeanp
Would you have the phone number for Internationl?
Old Jan 9, 2012 | 08:36 PM
  #28
dukie1877's Avatar
dukie1877
Ford Powerstroke Diesel 6.0 liter ICP Sensor & Plug 2003 | eBay
Great deal IMO free shipping thought I would share. sensor and pigtail $69
Emiland
Jul 19, 2024 10:36 AM
MelvilArnt
13
Nov 2, 2016 02:27 PM
grampscamper
Jun 23, 2016 03:13 PM
Pyancey
Jan 16, 2013 09:08 PM
