jet hot worth it?
Old Sep 8, 2008 | 04:04 PM
ol74hb's Avatar
ol74hb
jet hot worth it?
I am going to get new headers for my truck is the jet hot inside and out worth the extra 260$ or just go with the regular ones from headmen
Old Sep 8, 2008 | 04:17 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I cant give any first hand experience, but everything ive read, seen, and heard says yea it is. Takes the heat away from the engine alot better, and makes youre headers last alot longer. Had some regular painted header on my 76... the lasted about 7 years. When i get my swap headers for my 460 im goin with the ceramic coated / aluminized ones.
Old Sep 8, 2008 | 04:54 PM
dkf's Avatar
dkf
Not worth it to me. Have a set of $1k Thorleys on my SD and a set of cheaper ceramic coated long tubes on my 74' both rusted in short order. I use VHT header paint and a wire brush to keep the headers looking good.
Ceramic or Jet hot coating is just a glorified ceramic paint they put on, heat cure and polish in a vibratory tumbler.
I'd get regular painted headers, strip off the black paint and get a couple cans of VHT "Aluminum" colored ceramic header paint in rattle cans. (Around $6 a can) Thats what I'm doing next time around.
Old Sep 8, 2008 | 05:12 PM
dkf's Avatar
dkf
Originally Posted by UTfball68
dfk...thanks for the heads up on the VHT...never heard of that before...where can you pick that stuff up at?
Advanced and Autozone. The VHT is the best I've found thus far. I was using Duplicolor header paint because there regular paint is awsome, however VHT is better. I use a stout wire brush to get the old crap off and paint over it, the heat cured it.
Old Sep 8, 2008 | 05:22 PM
ol74hb's Avatar
ol74hb
what about the hi temp paint from eastwood says it is good to 1200 degrees
Old Sep 8, 2008 | 05:50 PM
johaner78's Avatar
johaner78
VHT is also available at O'reilly's if you care to shop there.
Old Sep 8, 2008 | 05:54 PM
dkf's Avatar
dkf
Way overpriced. VHT is supposed to handle 2000degF.
johaner78 thanks for chiming in about O Reillys, I figured they would have VHT paint but there is no stores in my area.
Old Sep 8, 2008 | 05:56 PM
dkf's Avatar
dkf
Alright thanks...I'm actually buying a set of cheap Hooker headers for my Bronco...and it only had the black paint so I started researching header paints, to do what you described, and hadn't seen VHT yet...gonna check it out.
The VHT paint comes in several colors. I just used the flat aluminum color because it matches the ceramic coating the best.
