header leaks????
Old Sep 7, 2008 | 04:03 PM
pipman76's Avatar
pipman76
Thumbs up header leaks????
i have finally swapped my 460 into my 74 f-100 and the headers had those factory exhaust gaskets and they didnt leak before but now that unhooked them and wnet into the 74 along with the engine they leak on both sides i even replaced the gaskets with new ones and the same thing is going on as well whats the deal? Do i need to go with cooper heder gaskets?
Old Sep 7, 2008 | 05:02 PM
rickh51's Avatar
rickh51
Back in my "earlier" years, we used to cut the header flange between the tubes so basically each tube had it's own flange. Worked back then. You might want to try that . . . . or not. Sounds like the flange is warped a bit. The copper or aluminum gaskets should take care of that though.
Old Sep 7, 2008 | 05:11 PM
rickh51's Avatar
rickh51
There is also a thread in the "small block" engine forum on header leaks you might want to check out.
Old Sep 8, 2008 | 07:32 AM
pidaster's Avatar
pidaster
The high temp copper silicone will help out as well.
Old Sep 8, 2008 | 08:01 AM
scottie2hottie's Avatar
scottie2hottie
I like the idea of cutting between the cylinders. My headers on my 460 came as two piece so the flanges were split new.
Old Sep 8, 2008 | 02:26 PM
pipman76's Avatar
pipman76
can u get that cooper silicone at a local parts store??
Old Sep 8, 2008 | 02:49 PM
dkf's Avatar
dkf
Its Permatex "Ultra Copper" high temp silicone, can get you the part # if need be. Its very common and I know places like Autozone and Advanced has it. Napa should too.
Old Sep 8, 2008 | 05:27 PM
pipman76's Avatar
pipman76
sure if u can get it but if not ill go tooo the local napa store and ask them about it.now do you apply this to the gaskets for a better seal ??
Old Sep 8, 2008 | 05:59 PM
dkf's Avatar
dkf
I usually put a light coat on the steel/cast iron instead of the gasket, don't know if it really matters though. You just want a thin even film of it and follow the directions on the tube.
Old Sep 8, 2008 | 07:12 PM
pidaster's Avatar
pidaster
dfk is correct. My next door neighbor has been a mechanic for years. My heads are pitted in places and all we did to fix it was put a good bead on the gasket, install it immediately, and bolt it down. The package says to wait and that might work too but for getting it to seal those small pits is why I squished it on immediately. Ultra Copper is the correct name. I purchased the last tube of it at O'reilly Auto.
