Sponsored by: Kumho
Steering Stabilizer
Old Sep 8, 2008 | 10:53 AM
riggz's Avatar
riggz
Steering Stabilizer
To anyone who has worked with or replaced a steering stabilizer before. Does it act like a standard shock where it always extends to it's maximum? Or does it have a halfway point that it returns to?
The reason I ask is that I have a shock that I'm using as a stabilizer and it seems that it would be constantly pushing out.
Old Sep 8, 2008 | 12:36 PM
75F350's Avatar
75F350
A sateering stabilizer has got to be valved 50 / 50, or it will cause a pull. ONly slight pressure is required to create a pull, and having different valving will dampen at different rates, creating a problem in either, or both directions.
Stabilizers are dampers, similar to shocks, but not like the shocks we use on our suspension. Many shocks cant be mounted in a flat position, or the oil will foam, and become saturated with air, and render the damper useless.
Only a stabilizer (not a regular shock) should ever be used on a steering component.
Old Sep 8, 2008 | 12:37 PM
riggz's Avatar
riggz
That's what I figured. Thanks for that!
2002exPSD
Feb 18, 2016 04:47 PM
smiley87
Apr 13, 2015 10:05 PM
vento
Dec 4, 2009 01:00 PM
audimaster
Jun 10, 2007 05:08 PM
epos48
Feb 27, 2006 07:21 PM
