Thanks Chris!!! Going to start on this at lunch, and hopefully not have any problems with it today... Hopefully!!! Rep Police wont let me send anything your way, sorry.
I know there is a rubber gasket between the HPOP reservoir and the engine front cover, but I'm not sure about one at the HPOP itself. I think Ron had a picture of a bad gasket at the HPOP reservoir not too long ago.
Okay, well, I have no O rings here, My Grainger has no stock, so I might be heading to Ford at lunch. Updated part number for the HPOP rebuild is 2C3Z-9G804-AB $28.00
Have you checked the yellow pages under seals / o-rings? It looks like there is a place called Martin Fluid Power in Troy that probably sells what you need. Might be worth a phone call. If you go that route, those types of places usually have a $5 or $10 minimum order. I'd use the O-ring list to grab a couple of other o-rings that you might need in the future.
