One of the hub locks is messed up. I had to use a tire iron today to turn the lock and engage. Then the inner part popped out a bit. I did a search and I am about to order up a set of Warn replacements. Couple of questions...
1) Do I need any other parts? (O-ring)
2) Is the procedure as simple as removing the snap ring, taking out the old lock, and putting in the new one?
