Help removing pulley on PS pump
Old Sep 4, 2008 | 10:46 PM
saleen065's Avatar
saleen065
I've read several threads that talk about installing the pulley and using the correct tool. How is the pulley removed? Just a standard bearing/pulley puller? Any tricks to it? My pump starts out just fine but once it gets warmed up it sounds like hell and actually starts to fade on it's ability to work so I am going to replace the pump.
Old Sep 4, 2008 | 10:53 PM
f250hiboy's Avatar
f250hiboy
Hello go to autozone an rent the power Steering Pump Pulley Kit....its easy todo with the right tools.....
Old Sep 5, 2008 | 03:27 AM
fmc400's Avatar
fmc400
MSEE
The pulley is interference fit. It requires a special tool to remove. Like f250hiboy said, you can rent the tool from Autozone. The power steering pulley puller tool looks slightly different than a standard pulley puller. I went ahead and bought my own and I think it was around $30 or so. Even with the correct tool, it takes a while to work the pulley off the shaft, but it will come off little by little. When you put the pulley on the new pump, be very careful that it goes on in the right direction. If you put it on backwards, it will be impossible to remove it because the puller jaws will have nothing to grab.
Old Sep 5, 2008 | 06:32 AM
cujo8's Avatar
cujo8
Make sure you get the PS pulley tool that both removes and installs the pulley. You don't just want to drive the pulley on w/ a BFH or you run the risk of damaging the pump. If you use a std pulley/bearing puller to remove the pulley you will ruin the pulley, don't ask me how I know:-( To prevent your new pump from wear and noise, install a PS fluid filter in-line on the inlet side of the pump.
Old Sep 5, 2008 | 12:09 PM
fmc400's Avatar
fmc400
MSEE
If I remember correctly, all that's required to install the pulley on the pump is a bolt, nut and washer which many new pumps come with. Torquing the bolt slowly works the pulley back down onto the shaft. The bolt them comes off when you're done. My pulling tool came with them as well.
Old Sep 5, 2008 | 05:40 PM
tankrsc's Avatar
tankrsc
Just curious are talkin about something like a remote Oil filter just hook to to return line of the power steering or a specific power steering filter? Honestly never thought about that but does seem to be a good Idea
Am replacing my PS pump tomorrow morn can purchase the tool from Advance here for $28 but think I will rent it from Auto-zone, just don't think I would use it enough to buy one.
Old Sep 5, 2008 | 05:44 PM
yard_dawg's Avatar
yard_dawg
got my pulley at auto zone, do not remeber how much,but it was not high at all. my new pump came with the bolt and washer, and nut to reinstall the pulley. it is not hard at all to do. good luck
Old Sep 6, 2008 | 07:46 AM
cujo8's Avatar
cujo8
I bought a 5/16" Magnafine AT Filter online (eBay) from a place called Technical Alternatives for $18.50 + S&H.
I did a quick search and I found them at JC Whitney:
Magnafine Dual Inline Transmission Filters : JC Whitney: Auto Parts & Accessories
Old Sep 6, 2008 | 10:32 AM
JohnT's Avatar
JohnT
Smile
When I bought a new ps pump for my 73 F100 at AutoZone, the guy working at AutoZone removed the pulley from my old pump and installed it on the new pump.
Old Sep 8, 2008 | 04:33 PM
atomicjoe23's Avatar
atomicjoe23
Cujo8. . .thanks for the pic's and the link to the filters!!!
Old Sep 8, 2008 | 09:49 PM
saleen065's Avatar
saleen065
UPDATE! It was a breeze to swap the pulley out. I already had the pulley remover too! I had forgot I even had it. I used my air wrench to remove it and then I used a ratcheting boxed wrench to install it. The trick I found was spraying the pulley and the shaft with silicone spray then install the pulley. It went on without any problems at all. Thanks everyone for your input. I finally have the truck cleaned up somewhat and on the road. I will post pictures when i download them off my camera.
mnewbolds
Mar 12, 2016 10:59 AM
daisyman
May 23, 2015 10:24 PM
Pete Kildow
Large Truck
Sep 27, 2013 04:46 PM
Jaaaaaaackman
Mar 10, 2012 08:53 PM
87_gt
Apr 9, 2009 09:49 AM
