Aerostar Ford Aerostar
transfer case whine?
Old Jun 21, 2004 | 05:40 AM
rml121's Avatar
rml121
I have a 1997 aerostar AWD 4.0 ltr that has developed a whine over the last few weeks. A few of the forums have said it maybe caused by low fluid. My problem is I have not been able to locate the filler on the transfer case. Does anyone have a diagram showing were the filer and drain plug is on the transfer case?
Old Jun 21, 2004 | 04:47 PM
JeffMasonCO's Avatar
JeffMasonCO
Have the Aerostar on level ground and crawl underneath. From behind the t-case, look at the rear of the case. You should see two big 1-inch bolts. IIRC, the one on the left side is the drain plug. The one on the right side (close to the rear output shaft) is the fill bolt. (It's hard to tell, but if you look from the side, you will see that the fill bolt is a little bit higher than the drain bolt.
Just remember to open the fill bolt before you remove the drain bolt. There's nothing worse than draining all the fluid out and then finding out the fill plug is stripped
Tim Shultz
Jul 4, 2013 09:45 PM
xltrangerflex
Nov 17, 2012 09:52 PM
gallatingator
Oct 10, 2011 01:36 PM
Mine2go
Dec 14, 2009 11:55 PM
SoArkSI
Nov 5, 2005 08:43 PM
