Got my IC and tubes in today also After seeing how flimsy the 6.0 plastic tube is how much pressure can it actually take? I know schedule 40 PVC isn't made for pressure but would it work??? Working with it almost every day it seems alot more sound than the 6.0 tube
With the tubes I got eye candy is the last on the list, they are pretty rough. The 7.3 tubes are alumiumn and look like someone took a pipe wrench to the one. The alumiumn 6.0 tube has a depression in the one pipe, not sure if it's factory or not. Figured with PVC it can be smoothed and painted.
The pipes I got were aluminum as well so I just found a friend who would had a SD with steel pipes and just swapped them. Might be worth looking into for you as well.
did we already have the conversation as to where you are located in pa? i may be able to help
Yeah, I'm about 4.5 hrs NW Gonna be making a trip to Lancaster and Reading sometime this fall just don't know when. If time's available I'm gonna toss in the sks and see what we can destroy LMAO
"I'd be worried about the heat with PVC pipe. Copper would be expensive!"
I've got enuf pipe, just not the fittings.....sure would look good though!!
