2002 Explorer Trans problems
Old Sep 2, 2008 | 11:40 AM
1's Avatar
02 ford exploder, shifts first and second free revs in third, o/d off keeps flashing too.
Tried a quick search and didn't find anything.
Old Sep 2, 2008 | 12:37 PM
jk080's Avatar
jk080
Transmission Rebuilder
I bet your code will be "incorrect gear ratio in 3rd" and the intermediate band is broke.
The only "non internal" problems it could be is a broken intermediate servo piston or a blown out valve body gasket, but I have seen way more broke bands.
The way you can tell if the band is broke is to see how far the band adjustment screw will screw in. If it turns more than 3 turns its broke.
The intermediate band adjustment screw is on the driver side closest to the rear of the trans, above the manual linkage. Loosen the "3/4" jam nut and turn in the "15/16" square headed screw.
Old Sep 2, 2008 | 02:45 PM
1's Avatar
Thanks so much.... I will take a look at that and let you know
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
