ballast resistor wire?
Old May 7, 2000 | 08:46 AM
b1rdjx88's Avatar
b1rdjx88
When I turn the key in my 82 F-150 4.9L, the engine starts fine, but as soon as I let go of the key the engine shuts off. i.e. when the starter is engaged it works, when its not it doesn't.
I have done some looking around and pinpointed the problem to either the ignition switch or ballast resistor wire. When I asked the guy at Canadian Tire (big department store originally based around cars) for a replacement ballast resistor, he had no clue what I was talking about and gave some bull***** about needing a new solenoid.
I have located the ballast resistor in the truck. Are there any ways to tell whether the problem is from the ballast resistor or the ignition switch? Also, would there be any harm in swapping the ballast resistor with standard 16 guage wire until I can get the replacement?
thanks in advance
Old May 11, 2000 | 08:04 AM
BB's Avatar
BB
I have experienced the exact same problems on my ’79 5.0L Capri and ’63 Falcon Sprint and guess what it turned out to be, the starter solenoid! There is a terminal labeled “I” which is the ignition ballast resistor bypass wire that goes directly to the coil to supply 12 volts but only when cranking. While running there is no voltage on this wire as power then goes through the ignition switch through the ballast resistance wire to the coil. What was happening was the “I” terminal worked in the “start” mode but when in the “run” mode instead of being open it was shorting out the coil. You might want to try replacing the starter solenoid first before you dig in any deeper.
Old May 26, 2000 | 08:00 PM
nitro94's Avatar
nitro94
ved0303
Jan 2, 2015 11:07 PM
harold
1978 - 1996 Big Bronco
Sep 9, 2007 07:14 PM
ftech
20
Sep 9, 2006 03:54 PM
packrat56
Nov 22, 2004 01:50 AM
b1rdjx88
May 13, 2000 09:48 PM
