Sponsored by: Real Truck
Brake Controller Installation
Old Sep 1, 2008 | 08:04 PM
willhf1011's Avatar
willhf1011
OK so I'm installing a brake box for a friend of mine and i was going in to do the wiring today and noticed that there are 3 wires sticking out of one of the harness tubes. They are all heat shrunk on the end for insulation and look to be factory. They are also red, white and blue, the same colors as on the brake box (save for the ground). The truck already has a 7 prong plug in the back with a blue wire to it for brakes, this makes me think that maybe these wires were installed factory to support a brake box if the truck came with a tow package? Anyways onto the problem, if these wires are infact for a brake box then i would like to use them for neatness of installation, problem being none of them are hot and so the box will not be getting juice, is there a fuse or relay somewhere that needs to be installed to light them up once you're ready to install a controller?
Old Sep 1, 2008 | 08:34 PM
DPorter's Avatar
DPorter
Customer access wires for add on accessories. Not for your brake controller.
Under dash to the left of the radio should be a brake controller plug to attach to the controller. You will need the adapter plug to wire to the controller wires then plug into the
harness and you are good to go.
Old Sep 1, 2008 | 08:37 PM
AzBlueWolf's Avatar
AzBlueWolf
if your friend got the truck new, there should be a package in the glove box with wire pigtail, a couple relays and instructions for wiring the brake controller
Old Sep 1, 2008 | 08:42 PM
Greywolf's Avatar
Greywolf
He's right - those wires should be capped off and the connector found. It may be next to the radio, but I've more often found them closer to the emergency brake.
There may also be a fuse on top of the fender liner in the engine compartment that has a dummy fuse in place, but not if it's already been used for towing. Look in your owners manual and go over the fuse designations carefully to see if there's one or two you might need to be aware of.
*The trailer turn signals are two that stand out in my mind.
That bunch is one wire short anyway. There should be a red(brake pedal switch), blue(controller output), white and black(power AND ground)
Never trust a controller to ground through its case.
Old Sep 1, 2008 | 08:44 PM
willhf1011's Avatar
willhf1011
does anyone have a picture of that?
Old Sep 1, 2008 | 08:45 PM
AzBlueWolf's Avatar
AzBlueWolf
eBay Guides - Adding Factory Trailer Brake Control To Your Super Duty
this sounds a little more expensive, but may be better in the long run...
Old Sep 1, 2008 | 09:54 PM
dkf's Avatar
dkf
I've installed a Tekonsha P3 ans Prodigy on an 03' and 04' SD. For both I paid the $10 and got the plug and play harness from Tekonsha. Plug the harness into the truck connector(Under dash below waayyy to the right), mount the controller and plug the contoller into the harness and done. I use factory plugs when I can.
Old Sep 1, 2008 | 11:16 PM
Greywolf's Avatar
Greywolf
Right or LEFT?
I've never seen the connector on the passenger side.
Old Sep 2, 2008 | 06:46 AM
AzBlueWolf's Avatar
AzBlueWolf
Drivers side, above the gas pedal, on the right side of the pedal
Old Sep 2, 2008 | 08:27 AM
dkf's Avatar
dkf
What he said.
Its a real PITA to get the plug into the connector.
silentrunning
Jun 8, 2024 05:47 AM
willhf1011
Feb 23, 2020 04:08 PM
Billy Hat
All Things Towing
Nov 28, 2014 12:59 PM
jwc9
20
Dec 15, 2013 06:28 AM
tobyw
Oct 16, 2001 12:07 PM
