if its a press on pully and its loose, lock tite wont do the trick, you would need to use bearing set. which is like lock tite, but for the other kind of force applied that locktite doesn't help against.
It firms up a bit diff then lock tite as well, to get the pully back off, you'd have to apply heat to get it to break down.
Bearing set has a set time as well.
yeah, got an entire new vac pump/pulley assembly...i've never done the replacement before and have no past records on my truck, so your guess is as good as mine as to if/when it's ever been done before!
