This is getting old pretty fast...
so, anyone with a lot of patience care to explain the replacement process to me? I haven't done much of anything mechanical on the truck yet...not much confidence in my ability, plus have to bum tools off my buddies cuz I have none
...but I miss my truck...terribly
Then the 3 bolts that hold the pump & IIRC one vac line
After the new pump is on ,re install the pulley ,,I would get a new pully also , they can only be pressed on a couple of times IIRC,,
you can rent or borrow the tools from most part stores ..
One is a puller ,,the other is to press the pulley back on...
****** content="Vacuum Pump" name=tps_proctitle><TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>SPECIAL SERVICE TOOL(S) REQUIRED </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Tool Number</TH></TR><TR><TD vAlign=top align=left>Fan Clutch Nut Wrench</TD><TD vAlign=top align=left>T83T-6312-B</TD></TR><TR><TD vAlign=top align=left>Fan Clutch Pulley Holder</TD><TD vAlign=top align=left>T94T-6312-AH</TD></TR><TR><TD vAlign=top align=left>Steering Pump Pulley Remover</TD><TD vAlign=top align=left>T69L-10300-B</TD></TR><TR><TD vAlign=top align=left>Steering Pump Pulley Replacer</TD><TD vAlign=top align=left>T65P-3A733-C</TD></TR></TBODY></TABLE>
Removal
- Remove drive belt (8620).
- Partially drain engine coolant.
- Remove upper radiator hose clamps and upper radiator hose (8260).
- Disconnect coolant reservoir hose at radiator and support.
- Remove fan blade (8600) and fan clutch (8A616) using Fan Clutch Nut Wrench T83T-6312-B and Fan Clutch Pulley Holder T94T-6312-AH. Set fan blade and fan clutch in fan shroud (8146).
Removal
6. Remove two fan shroud screws.
7. Remove fan shroud, fan blade and fan clutch.
8. Remove vacuum pump pulley using Steering Pump Pulley Remover T69L-10300-B.
9. Remove vacuum pump bolts.
10. Disconnect vacuum pump hose and remove vacuum pump (2A451).
Installation
1. Connect vacuum pump hose and install vacuum pump.
2. Install vacuum bolts. Tighten bolts to 23-32 Nm (17-23 lb-ft).
3. Install vacuum pump pulley using Steering Pump Pulley Replacer T65P-3A733-C.
4. Position the fan shroud, fan blade and fan clutch.
5. Install fan shroud screws.
6. Install fan blade and fan clutch using Fan Clutch Nut Wrench T83T-6312-B and Fan Clutch Pulley Holder T94T-6312-AH.
7. Connect coolant reservoir hose at radiator and support.
8. Install upper radiator hose and hose clamps.
9. Refill engine coolant.
10. Install drive belt.
Vacuum Pump and Bracket
Item Part Number Description
1 N605790-S2 Bolt, Vacuum Pump-to-Bracket
2 2A451 Vacuum Pump
3 3A674 Power Steering Pump
4 26487 Vacuum Pump Pulley
A — Tighten to 23-32 Nm
(17-23 Lb-Ft)
Now, when I did mine I didn't have to remove the fan and shroud I just got in there with my greedy little fingers. I don't remember removing the bracket either. IIRC there is a hole in the pulley that you can use to get to the pump bolt behind the pulley. The pump should come out by itself with the pulley attached. Then swap pulleys or in your case put the pump in with the new pulley.
yeah...it turns but most def NOT freely...
found this: eBay Motors: FORD 7.3L DIESEL MECHANICAL VACUUM PUMP (item 140265324978 end time Sep-13-08 05:01:40 PDT)
which will leave the fun part- figuring out how to get my truck and my free labor (i.e. buddy who knows way more about diesels than me!) in the same place so I can learn with supervision
I want to try electric fans, but am not finding anything to my liking.
Oh well...another project for another day. Good luck with this.
I think if you pull the pulley off and turn it around, press it on until it is flush with the shaft I think your problem will be solved. Be sure to add a bit of locktight as mentioned eariler.
I hope this helps
Kevin
~ so if everyone keeps taking fans off and leaving them off...then exactly what purpose are they supposed to have??
The pulley presses onto the shaft of the pump from the factory. Once you do it you'll see how tight. The design works. All the bolt in the end of the shaft would do is hold the pulley on? Not needed and leaves something to rattle loose and fall out.
Some parts stores will even rent the puller set. It grabs on to the center hub and pulls it off of the shaft.
