Offroad & 4x4
D60 Front Axle Problems
Old Aug 30, 2008 | 02:26 PM
Prozon's Avatar
Prozon
I have an '88 F-350 with Dana 60 reverse in the front. (Solid of course.)
"The axle shaft appears to be loose. I can wiggle it at the u-joint (up and down, not in and out), but the wheel itself seems to be tight."
Quoted from Fullcrew7.3
I have the same problem with my U-Joints and when I am in four wheel drive my front axle makes pretty nasty sounds.
I have not been driving my truck for quite some time because of an engine problem. I'm putting a better conditioned 460 in it but i'm rebuilding the new one before it goes in, so my truck will be off the road for awhile.
I was wondering if anybody knew what is wrong and what needs to be replaced.. and if possible how?
I don't do much with axles. The most I have done is change my rotor when my brakes went out. (Which I may add was the worst looking rotor I have seen in my life.)
Any help appreciated.
Off-Topic
That thuur is a perrrrty rotor.
Didnt even occur it was bad untill it destroyed a caliper and my brakes went out.
Old Aug 30, 2008 | 05:21 PM
mark a.'s Avatar
mark a.
If you are saying you can lift the axle up and down at the u joint, but the u joint seems to be ok ? Then I'd say the spindle bearings are shot.
Old Aug 30, 2008 | 05:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
http://www2.dana.com/pdf/5326.PDF
Look at page 5, parts from 47 to 51.
Yeah I know that is a 50 IFS, but the parts picture is better than the one on the 60 axle.
Old Aug 30, 2008 | 10:00 PM
highboy1975's Avatar
highboy1975
yep, bearings would be my first guess on this one too.
Old Aug 31, 2008 | 07:54 AM
Fullcrew7.3's Avatar
Fullcrew7.3
With mine, it was definitely the spindle bearing. Not sure about on an '88, but on my '93 axle, other than not having the locknut tool, it was pretty easy to get apart.
Old Aug 31, 2008 | 09:39 AM
ibleedblue1385's Avatar
ibleedblue1385
x4. spindle bearings.
Old Aug 31, 2008 | 03:47 PM
Prozon's Avatar
Prozon
Thanks. As I said i'm swapping the engine first so i'm not in a big hurry.
Ford SD
Mar 31, 2015 03:05 PM
2500ak
May 8, 2013 03:17 PM
Ron Kelley
Nov 2, 2007 10:40 PM
pyropierce
2004 - 2008 F150
Sep 5, 2007 06:38 PM
Kenny
Dec 15, 2003 06:43 PM
