D44 or D50 front axle????
Old Nov 1, 2007 | 01:42 AM
Ron Kelley's Avatar
Ron Kelley
Okay here it is. I am really wondering what I might have in this 85 F-250 4X4 extended cab truck. I am curently in the middle of replacing a lot of parts on the front drive axle of my truck. I replaced one brake rotor all three u-joints and obviously all related seals and gaskets. Here is the question that I have. Is there or has been a joining of the D44 and D50 front axle. The grease seals on the rotor are a part #that matches to a 50 axle. Plus the hubs just about fill the holes in the wheels. When I went to Napa yesterday to buy the front diff gasket (this is after I figured out from all of your help here that I needed to remove the front diff to get the right axle out of it) I asked for a D50 gasket. Took it home and its way to big. The front diff gasket ended up being a D44 part #. What is this? ever heard of this or is this common. Just curious.
Old Nov 1, 2007 | 02:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to the confusing world of Ford 4WD front axles. Is it a Dana 44, a Dana 50 or a Dana 60? That depends on the GVWR: under 8500 lbs, or over 8500 lbs. It also depends on the type of hubs and the ratio. There are 10 parts lists for under 8500 lbs, and 3 parts lists for over 8500 lbs.
What do you have? Good question. Did you find an ID tag on the axle? Besides being bolted to one of the bolts that holds the removable cover on (where it usually disappears), it may be on the right axle tube adjacent to the cover. This tag is approx 2" long by 1/2" wide, and is held to the tube with two bolts. The code could be either all numbers, beginning with 6 (6xxxxx-x) or a Ford engineering number like: E5TA-AA.
I tried to look up the parts you have questions on, but without that tag number...I can't help you.
Old Nov 1, 2007 | 11:29 PM
Ron Kelley's Avatar
Ron Kelley
Ido have the tag but it is mostly unreadable. I did bolt it back on right where I found it just in case for the future. I was talking with the snap-on dealer that came in tonight to work and I was asking him about these trucks. He just laughed and said that when he was working at the Ford dealership in the mid eighties they didn't have a clue what they were working on themselves until they got it apart either. He told me that a mixture of the D50/60 hubs were routinely mated to a D-44 differential. Just like you said it depended upon heavy duty(high gvw) or light duty(lower gvw). Neat stuff.
Old Nov 2, 2007 | 01:22 PM
andym's Avatar
andym
It *should* have a Dana 50, being an extended cab. But it sounds like Ford screwed you over by giving you a 44 differential and 50/60 hubs.
Old Nov 2, 2007 | 05:22 PM
Sycostang67's Avatar
Sycostang67
Thats exactly what a D50 is, it's a D44 center section with D60 outers/hubs. A regular F-250 4x4 will have an HD44 basically a D44 with 8 lug rotors/hubs and a semi-float rear axle. If you have an F-250HD then you got the D50 and a full-float rear axle. The D50 and D44 gears are very similar, but not interchangeable so I've heard. I had my gears swapped, and the box application was for a D50 but the guy who put the old gears in the box thought they were for a D44.
Old Nov 2, 2007 | 05:28 PM
andym's Avatar
andym
Ok... so *that's* what a Dana 50 is. I thought it had a larger ring gear as well.
Although I know there are HD F-250's with Dana 44's. I've seen them on the road around here.
Old Nov 2, 2007 | 10:40 PM
Ron Kelley's Avatar
Ron Kelley
Now isn't that something?
nossliw
Offroad & 4x4
Nov 30, 2011 08:43 PM
77f2504by4
May 18, 2008 12:18 PM
Never_a_Chevy
Feb 26, 2006 12:35 AM
KJKozak2
Jan 16, 2003 08:58 PM
