Sponsored by: Auxito
98 F-150 CD Changer Problem
Old Aug 30, 2008 | 12:27 PM
rmckenna's Avatar
rmckenna
Can anyone tell me how to remove the CD Changer that is behind the drivers side door. My CD unit stopped playing and only keeps changing CD, but does not play anymore. I've removed the rubber gasket around the CD Changer, but not sure if I have to remove anything else.
Old Aug 31, 2008 | 10:01 AM
wuff's Avatar
wuff
I also have the same problem, I've resorted to cassettes I only could find a few worth listening to. Hope someone can answer soon I'll be watching .
Old Jan 16, 2010 | 05:42 PM
97F250Lariteer's Avatar
97F250Lariteer
The service manual doesn't talk about the panel that covers the CD changer. Anyone have the steps for removing it for cd changer access?
Old Apr 26, 2011 | 02:11 PM
Roamingdoc's Avatar
Roamingdoc
Anyone ever get this solved? I've the same issue but not seen a schematic or anything that looks good aside from dynamite. Thanks
Old Apr 26, 2011 | 02:35 PM
Johnny Langton's Avatar
Johnny Langton
I removed the changer unit from my '98 F150. it's not an easy task at all. You must remove the entire rear seat,and ALL of the plastic trim panels that are on the interior body in order to access the mounting bracket bolts. It would be a great time to install aftermarket speakers back there if you're thinking about it-it's the same process to change that driver's rear speaker.
JL
Old May 17, 2011 | 11:22 PM
97F250Lariteer
Thanks for the info, I haven't got up the ambition to tackle this yet as I don't drive the truck to much anymore.
Old May 19, 2011 | 09:34 PM
97flairside's Avatar
97flairside
ughhhh, i have the same problem. I just want my dam Metallica CD's back!!!!!!!
Old May 21, 2011 | 12:30 PM
BFTUFF's Avatar
BFTUFF
The procedure is in the Ford workshop manual. JL is absolutely right, a lot of work to get to it. By the way, the CD changer is made for Ford by Clarion. I like it a lot better than the new menu drive after market units. All the buttons are right there for instant adjustment, just the way I like it!
rnnrrnnr
Feb 13, 2012 04:52 AM
bryyce62
Jul 17, 2011 02:03 PM
stangman516
1997 - 2003 F150
Nov 19, 2009 07:05 PM
D Ray
May 25, 2006 03:15 PM
damonlan
Jul 20, 2003 04:16 AM
