Sponsored by: Real Truck
tire time....315?
Old Aug 26, 2008 | 09:50 PM
spr1516's Avatar
spr1516
Question tire time....315?
time for new tires i want to go 315/70/17 hankook m/t on a 7.5 wheel will it work i have a lift so thats not a prob? its just a every day driver
Old Aug 26, 2008 | 11:51 PM
riggz's Avatar
riggz
They will probably fit but will balloon out. They could also develop a hop as the tread won't be allowed to sit flat. I'd suggest going with at least an 8.5" rim.
Old Aug 27, 2008 | 12:27 AM
cartmanea's Avatar
cartmanea
I don't know how different 17s should be, but I run 315s on 8" wide 16s and they fit very well. Really though you should probably stick with a 295 or maybe a 305.
Old Aug 27, 2008 | 04:05 AM
AllAboutDaZ's Avatar
AllAboutDaZ
i heard they do fit but you do get the bubble effect
Old Aug 27, 2008 | 08:55 AM
spr1516's Avatar
spr1516
im just looking for a big tire to fill the wheel wells better than the 265/70/17 that r on there.. an i want to go wit a m/t but hankook only makes a 315/70/17 or a 285/70/17 nuttin in the middle
Old Aug 27, 2008 | 10:14 AM
cartmanea's Avatar
cartmanea
The 285 would fit a lot better if you don't have a lift or leveling kit.
Old Aug 27, 2008 | 10:27 AM
spr1516's Avatar
spr1516
i have a lift so thats not the prob its the rim size maybe ill go wit a 285/75/17 but i like the hankook mt an they only come 315/70 or 285/70 an i need atleast a 34" tire an the 285/70 are 33"
Old Aug 27, 2008 | 10:33 AM
ffadragon's Avatar
ffadragon
He said he has a lift. So he can go with 315's he just needs wider rims. If it is a daily driver I would go with a 9 inch rim, so they are not ballooning and you will get better tread wear.
How big is your lift? That is a key factor in how big of tire you need. If you have 3 inches or more I would go with 315. If is 2 inch leveling kit go with 285, 295 or 305. They are all pretty much the same just a 305 is an inch wider, 305 you might need a wider rim also.
Old Aug 27, 2008 | 10:53 AM
spr1516's Avatar
spr1516
3-1 inch lift now if i go bigger wheels how do i go about the locking hubs do i take them out or??
Old Aug 27, 2008 | 10:54 AM
spr1516's Avatar
spr1516
now what about a 285/75/17 open country mt on the 7.5 wheels? i think thats a 34.1
Old Aug 27, 2008 | 11:02 AM
Ace!'s Avatar
Ace!
I think the Toyo would be perfect for what you want to do. I wish I had gone that route.
I have 295 on a 7.5" width wheel and it works fine, but the 285 (in my opinion) would fit better on the wheel and is taller than the 295/70/17 I bought.
Old Aug 27, 2008 | 11:03 AM
cartmanea's Avatar
cartmanea
That would be a good size and a great tire.
