i have a 2002 super duty and it has a 4" lift on it and i just finished installing 2" shackles on the front..and now the sway bar doesnt line up with the mounts off the frame like it is too low. So do i need like a extended sway bar mount or do they make those?
You can drive it now, but I would pull the sway bar completely out until you can get some extended end links. I don't know where to tell you to look for the extended end links but I know they are out there.
You can try flipping the end links frame mounts to the under side of the frame rail. That might give you 2" back. If you already had 4" of lift there should have been some extended or adjustable end links already in place. If not, you definately need some with 6". Check out Amazon.
yeah i am about to purchase the end links myself but i need a sway bar as the person i bought the truck from seems to have took off the front sway bar completely
I still haven't gotten longer links for my 4" springs. The stock ones don't interfere with anything, just hang at a slight angle. Truck handles fine, is this really a problem?
