Offroad & 4x4
D60 Lock Right Install (write-up)
Old Aug 26, 2008 | 08:17 AM
bigrey6306's Avatar
bigrey6306
thanks for all the rep guys!
and im in san antonio tx, so I see ice and snow about as often as I see polar bears
So for me, it works
But I agree it would be bad up north (lived in NY for 4 years)
Old Aug 26, 2008 | 05:14 PM
suzuki1750's Avatar
suzuki1750
Originally Posted by unrulee
That's why I would have to go with ARB's or something similar here in the northern part of the nation. Limited slips can even give you a scare if your not expecting it.
But for a trail rig (or one that doesn't see ice/snow) this is a very viable option.
Yes, i agree. Off road they are great. I run one in the front of my suzuki.
I am curious how well that lock right will hold up in a front d60 with say... 40's?
On another note, if they offer the lockright with the "factory side gear "option, I would go that route.
From personal experience, the aftermarket side gear set has a tendency to slip more. Especially if your axle is tweeked.
I am new to d60's so that might not be an issue.
Old Aug 27, 2008 | 12:26 AM
maverick1701's Avatar
maverick1701
Originally Posted by bigrey6306
thanks for the rep!
its an "automatic" locker
it is always locked, but unlocks when you turn, allowing the outside tire to spin faster
The gears overrun eachother to allow the difference in speed
Its probably not the best if you drive in 4wd on the road alot
So its almost a more aggressive version of limited slip...almost?
It would sure be nice to throw one of those in.... I have been trying to find a cheaper locker. One thing I have never really understood is if I were to throw one of these in my dana 60 (front axle) would I still need to hop out and lock the hubs if the locker is always engaged?
Old Aug 27, 2008 | 06:30 AM
fishmanndotcom's Avatar
fishmanndotcom
yes.
all your hubs do is lock them to the axle shafts. the trasnfer case locks the driveshaft to the transmission. a locker/limited slip will make both axle shafts spin no matter what, it has nothing to do with having to get out and lock in your hubs or not
-cutts-
Old Aug 27, 2008 | 08:13 AM
teds74ford's Avatar
teds74ford
Nice writeup! I installed one of them in my rear 60 about 5 years ago. No problems so far, but I don't drive too aggressive. For what it is worth, I took my carrier out and installed it on the bench.
Do you have any action videos with it installed?
Old Aug 27, 2008 | 08:24 AM
bigrey6306's Avatar
bigrey6306
not yet, been too busy
But hopefully (if the wife lets me) Ill get out into some mud this weekend
Old Aug 27, 2008 | 04:35 PM
suzuki1750's Avatar
suzuki1750
thanks for the rep!
One thing to keep in mind. The locker will only unlock when it is not under load. If you are accelerating when turning, the locker will engage and both tires will turn at the same rate.
Old Feb 27, 2009 | 11:29 AM
JIMRSX's Avatar
JIMRSX
Now that you have had it a while, how do you like it? Would you do it again, or use a different locker? I'm thinking of installing one of these to help me not get stuck when I go to the beach, Have you had a chance to try it out in Corpus or Port A? Sorry for all the ?'s, and thanks for a great write-up.
Old Feb 28, 2009 | 12:24 AM
dave2180's Avatar
dave2180
Nice write up man. REP given! Hopefully I can install one in my truck too.
Old Mar 4, 2009 | 10:24 PM
bigunred's Avatar
bigunred
nice write up and great pics, also wonderin how much you like it
Old Mar 5, 2009 | 11:07 AM
bashby's Avatar
bashby
I put a locrite in my buddies cherokee(rear). He wants to take it out, it wont ratchet like its supposed to..its like a spool
Old Mar 5, 2009 | 04:04 PM
Blt Ford Tgh's Avatar
Blt Ford Tgh
Repetitive but....nice job on explaining everything
However, I would like to give advice to other at home mechanics...
DO NOT WEAR SANDALS when dealing with heavy metals hahahaha....toes go squish very easy so wear those steel toes
Midwest Dually
1983 - 2012 Ranger & B-Series
19
Mar 20, 2024 02:15 PM
mwvdub
1966 - 1977 Early Broncos
20
Feb 5, 2012 10:50 AM
cpoer
Dec 24, 2011 04:37 PM
low53
21
Aug 21, 2009 05:22 PM
Manwith3fords
Jun 13, 2009 03:51 PM
