Sponsored by: Real Truck
PATS key workaround
Old Aug 25, 2008 | 11:42 PM
aldridgec's Avatar
aldridgec
Just went out and checked.
Pictures worth....
2002 Ford F250 4x4 - Superduty Key Cylinder Removal
Old Aug 26, 2008 | 08:59 PM
mcjones44us's Avatar
mcjones44us
I've got another solution for the pats key workaround... Call DP Tuner and get a computer that bypasses it. About $200 is I think what I paid. Get to bypass pats and 80hp econo.
Old Aug 26, 2008 | 09:50 PM
cobrarep's Avatar
cobrarep
Pictures worth....
Chris - that's great!
Thanks very much for the info! Will give it a try tomorrow, looks pretty simple.
Old Aug 27, 2008 | 10:16 PM
cobrarep's Avatar
cobrarep
Pictures worth....
Thanks again Chris - too easy!
I got it apart, taped my PATS key in above the ignition cylinder and it now starts and runs fine with the standard Ford key.
Little tricky fitting that big key in a place where the shrouds would fit back down but I got it. I'll try this for a while, can always take it out if I feel the need for the anti-theft AND feel generous enough towards Ford to get a second PATS key.
Thanks to all for your help!
Old Aug 27, 2008 | 10:23 PM
Beerstalker's Avatar
Beerstalker
You could cut the long metallic portion off and just put the plastic end in there if you wanted.
rjent
1997 - 2003 F150
24
Jul 18, 2017 06:19 AM
chromiumh1
Jun 14, 2017 08:00 AM
christaylor
Dec 28, 2013 10:07 AM
cobrarep
Aug 26, 2008 10:56 AM
cobrarep
Aug 3, 2008 01:13 PM
