how do I remove front motor mount?
Old Sep 21, 2008 | 07:41 PM
bigwin56f100's Avatar
bigwin56f100
The man you spoke of is 100% wrong on the cam bearing. It just doesnt happen as often or ever as people once thought.
I have a pair of crappy boards left, YOU may think they are great, but believe me they really are junk. The left one is probably the best of the two.
Old Sep 22, 2008 | 09:54 AM
WALFORD'S 56's Avatar
WALFORD'S 56
Bigwin--I may have a pair of new boards coming--have not heard back from him yet. I am in need of rear fenders and boards for 1 of these trucks--are yours that bad? Can you send a pic of them?
I thought the same thing when he said that,about the cam bearings. Some people look at it from the worst case scenerio. (sp) But my engine is clean as a babys but inside---I need to remedy this before it gets coldout.......Bill thanks Kevin
Old Nov 5, 2008 | 08:56 AM
WALFORD'S 56
Well--I torched the 64 front mount off--and awaiting to decide to install another yblock and 4 speed into this frame. The 64 engine will be set aside for now. It is a shame--yblocks do not all interchange the way other engine families do......Bill
Old Nov 5, 2008 | 10:15 AM
bigwin56f100
All Y blocks ARE the same, all you need to do is utilize the correct hardware for the application.
Its no different than a 70 nova 350 and a 58 corvette 283, they are the same basic castings except the mounts are different. The nova is what I would cal text book side mount and the 58 vette had an upper front mount.
One cant expect an engine from 8 years later with upgrades, updates and design changes to be a "bolt in" swap with no problems.
So you torched the mount off, does that tell you how to put the new mount on? I would have removed the balancer, removed the mount, installed the correct mount, reistalled the balancer, made sure the mix of parts were ok to use.
Long story short. a 292 from any year will fit in a 56 with the correct hardware.
Kevin Y Block Bigwin
Old Nov 5, 2008 | 05:23 PM
WALFORD'S 56
Well I have decided to go with the 1956 F500 272 with 4 speed and forget about the 292 /3 speed---it will set in another 56 till I can deal with it.
I have had alot of vehicles and done lots of swaps and the yblocks are definately a weird bunch. I loaned out my puller and never got it back---I will and will raise some hell when I do!!---So I torched the 64 mount--but the 56 mount won't work either.
So I will install the 272 4speed in 56 f100 no.2 and be done with it in a week. My next 56 f100 will have a 351/302 and see how that works. Bill ''the painter''
Old Nov 5, 2008 | 10:01 PM
46yblock's Avatar
46yblock
There is no telling from anything above about the condition of the engines. However, the '64 with three speed would be a fully synchronized 3 speed top loader. It was a big improvement.
I do not understand the difficulty. But if you need a front motor mount for the '56 272 I have an extra which could be had.
Old Nov 6, 2008 | 05:27 PM
WALFORD'S 56
I have a 56 yblock front mount. The problem is the 1964 yblock has a different harm balancer and the mount is also different. I have already decided to install the 56 yblock anyway. The problem will then be solved.....thanks
jg513
29
Apr 18, 2017 07:29 PM
Outlaw56
Feb 23, 2017 09:23 AM
DieselCamper
Offroad & 4x4
May 18, 2016 06:34 AM
Chevmn56
May 6, 2014 06:32 PM
z1121jack
Jun 22, 2010 06:58 AM
