Bellhousing bolt pattern?
Old Aug 23, 2008 | 06:59 PM
heythere2581's Avatar
heythere2581
I need to know what the bell housing bolt pattern is on a 7.3 PSD. I want to make an adapter so that I can bolt a 4r100 behind a 5.9 12v cummins. I have tried looking everywhere for this info, and I can't find it, maybe some one has a bare block around Philadelphia that I could borrow and take to a machine shop and have measured, or maybe you have the specs already, please help me out here, I know they make adapters, but they are really $$$$$$$ and I have heard many horror stories about them not being quite right, I have already priced out what it would cost with a local machine shop and it is looking like it might work out better to do it my way, thank you in advance.
Old Aug 23, 2008 | 07:05 PM
ron's power stroke's Avatar
ron's power stroke
destroke.com has just a thing..Jeremy is doing a destroke... have a look..you will find your answer in there..or maybe he could help you with what you need..
https://www.ford-trucks.com/forums/7...on-update.html
Old Aug 23, 2008 | 07:32 PM
xgatorx1976's Avatar
xgatorx1976
Pull the adaptor plate off a 6.9 or 7.3. Use the trans holes to make new plate,or drill new hole in that on for the cumapart. The E4OD and C6 have the same bolt partern as the 4R100 due to the powerstroke started out with the E4OD.
Old Aug 24, 2008 | 12:40 AM
jtharvey's Avatar
jtharvey
I can understand the money thing, but as far as fit goes, I can tell you that the Destroked adapter plate is top notch. There are absoutley zero issues with fit on that plate. Everything bolted up just as it should, both to the block and the transmission to the plate. Nothing was at all was not in alignment, even by just a little bit. It fit perfectly. Scott at Destroked makes some first class pieces.
Old Feb 11, 2016 | 06:41 AM
crisptrans's Avatar
crisptrans
Fwiw, I believe the pattern is the same as a 460ci.
Old Feb 11, 2016 | 07:22 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
FWIW, I know that's wrong.
Old Feb 11, 2016 | 08:08 AM
Walleye Hunter's Avatar
Walleye Hunter
Man that's an old thread from 2008.
fordf348
Sep 13, 2017 07:37 PM
svastano
Aug 15, 2017 03:22 PM
fordf348
Jan 9, 2017 12:28 PM
FordmanNJ
All Things Towing
Mar 5, 2016 07:27 AM
ironmikey
Mar 1, 2016 03:30 PM
