So what pressure were you able to hold before? Maintain was monitoring mine while jetting down the back roads on the way to the diesel drag days, and just getting into it for 10 seconds or so, he said i was holding 2600psi... It would be nice if i could get it up to 2900-3000
2600 is not that shabby Kris, but I bet that is why the truck is not reaching its potential, especially with your single shots. I am not sold on the Turbonetics unit either. BTW, Jody told me mine was holding 2800 during live tuning.
now that my turbo problem is fixed..i did a WOT run in stock...I sent it to Rich (white buffalo) to transform so I can post..when hit the limiter from 65 MPH the DC was 41.4 and ICP was 3041.48 when I hit the limiter dropped off a bit to .2620.64 ICP and DC was 36.33......I didn't get time to do the test in 80 E but I will tomorrow when my girlfriend can run the putter...
Ron,
You should be able to record and playback using AE. You an playback the session and switch back and forth between Live Data Meters, Live Data Graphs 2x or 4xor Live Data Grid. While monitoring live data hit the record button in top left of screen. It will prompt you from there. You have to disconnect vehicle to playback. Playback is in the drop down menu under Data Logging. It is in the manual but took me awhile to figure it out. In my manual Data Logging begins on page 61. I hope you find the info.
i tryed that and tryed to record in graph..still saves as data...
When I go to playback I get a pop-up and then just check what I want played back and it comes up on the AE acreen in Live Data Meter mode and then I can click either one of the graph modes and watch the playback. I have version 6.2 for PC.
Here you go Ron: Let me clean it up some more, can't read the time on the X axis too well and I don't like the block lines......
Graph is in stock tune, let me know when you datalog in Tow & daily settings - that will show you how well the pump is holding pressure under extra HP settings
thanks Rich...duty cycle is a little high isnt it?? or is it cause i let up for a sec...stupid car was on the phone and came into my lane for a second..ill get better readings tomorrow..my girlfriend will run the puter..i can do the driving..
yes it does and read it in graph but still cant save it as a graph like Rich posted..
What you can do is pause the live graph and take a screen shot using some type of screen capture software that allows you to save it.
I use Printkey 2000 to save the graph. I wish I could do it like Rich. Seems easier I think.
But I "go with what I know".
