17 pump is in..
Old Aug 23, 2008 | 07:46 PM
ron's power stroke's Avatar
ron's power stroke
thanks Justin..injectors is all i need now...but not sure if i should do a BB turbo first....
Old Aug 23, 2008 | 07:50 PM
F350-6's Avatar
F350-6
Thanks for the info. That was a pretty big chuck of gasket missing, so I wasn't sure how much oil it would drip. I'm also not sure where the missing piece would have gone to since it doesn't seem like there's room for it to just fall out (or in for that matter).
Old Aug 23, 2008 | 07:58 PM
ron's power stroke
still havnt found that piece..its been leaking since i had the truck,,wasnt a lot of oil so really didnt worry about it...its the front side of the pump..right where the EBPS sits..
Old Aug 23, 2008 | 08:12 PM
jhand124's Avatar
jhand124
Turbo first that way nothing gets hurt. Congrats on the swap. What are you thinking on the injectors, SS of some kind I assume.
Old Aug 23, 2008 | 08:20 PM
ron's power stroke
havent really thought about it just yet,, i want a little over 400 hp when im done..
Old Aug 23, 2008 | 10:54 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Do the injectors first, you wont really notice an increase in power from a turbo.
Old Aug 23, 2008 | 11:46 PM
white Buffalo's Avatar
white Buffalo
got some ## but cant post it here... how do i make this a file to post here ??
Ron what #'s did you get. ICP, duty cycle?
If so, open the microsoft excel spreadsheet file that AE saved the dataloging in. Then, you can select the chart wizard and change it to a graph. Then change the file to a JPG and add it to your post
I'll PM you my phone # if you need the extra help - Mike (Tenn01PSDF350) had to walk me through it the first time I did it - then he made me drink....
edit: That's great you got the pump in - know you've been waiting impatiently for this mod.....
Old Aug 24, 2008 | 12:09 AM
Tenn01PSD350's Avatar
Tenn01PSD350
I don't recall a whole lot of arm twisting at any time. Now have a beer.
BTW, I just showed Theo this post. She says that is not how she remembers things going down when you were here. She says you made her drink.
On topic, glad you got the pump in and the leak fixed Ron. That reservoir pretty much should have leaked like a SOB at LPOP oil pressure. I am a bit confused here. I am not surprised you found black oil in there. One of these days I am going to fully explain this phenomenon with pics. No pics means nobody believes you.
Old Aug 24, 2008 | 12:12 AM
white Buffalo
I forgot about that part......
Old Aug 24, 2008 | 02:04 AM
TerminatorEng.'s Avatar
TerminatorEng.
but the RPM's bounce about 50 rpm at idle...not sure what's up with that just yet
Joey told me they are re usable and I shouldn't need it..I'm almost at 200k miles and thought id have one just in case
Hey Ron, your probably experiencing air in the system. Put some miles on and it will most likely smooth out for ya.
I had NO idea you had that many miles or that you had a leak. Glad you got it taken care of!
Old Aug 24, 2008 | 07:03 AM
ron's power stroke
thanks for the help.i guess i need to subscribe to do this..its asking for product key ## ..the one i have is 3 years old and i guess it wount except it..im a little low cash right now..i did a wot run from 40MPH to 100MPH when i blew a IC boot.. icp climbed steady to 2706.06 ICP DC was 37.89..i think i still have a boost leak some place..dont know if that hurts it or not...
there is not alot of PSI behind the front cover..no more then the CCV puts out any ways...i was suprised it didnt leak any more then it did too..the oil was very very black..dip stick still show's clean with a little tint of black.4000 mile on this oil....i cleaned the stick off and compared the oil from both stick and reservoir on my fingers...the reservoir was by far darker..
i for got about that leak when talking to you..i thought it was comming from behind the drive gear plate behind the EBPS cause it didnt leak all that bad..189K is a lot of miles ?? lol..she is just breaking in....thanks for every thing Joey...
Old Aug 24, 2008 | 08:01 AM
white Buffalo
PM sent Ron, If you like you can e-mail me the excel file and I will change it over to a graph for you. Was it the AE that was asking for the product code?
Old Aug 24, 2008 | 08:04 AM
  #28
ron's power stroke
no it was microsoft office.but the chart is microsoft excel...didnt know it could be done though AE..PM me you email..ill send it to ya..in the mean time ill play with AE trying to change it..
Old Aug 24, 2008 | 08:11 AM
  #29
white Buffalo
no, not through AE as far as I know, I use excel to change it over to a graph.
Old Aug 24, 2008 | 08:20 AM
  #30
ron's power stroke
email sent..2 files..thanks a lot Rich..ill rep ya when it lets me...
