Now that thats answered, how do the post counts relate to the user level (such as new, junior, senior, etc)? I've seen it asked before but nobody really knows the answer.
If you're a supporter, you can customize your user title to be whatever you like.
Just noticed I got some reputations.
Whats that all about? Should I reply?
But, goodonyafellas, I appreciate it
Gidday!
(Sorry, just thought I would say hello to a fellow Aussie!), I see you are from Ardlethan... I used to live just outside Shepparton.
Are you on a farm up there?
FTE will 'default' the title to wherever you are in post count.....When you get into the thousands, it'll default to 'post fiend', or 'post guru', or 'posting legend', or whatever.
If you are a non-supporter, you are stuck with whatever they hand you. If you are a supporter (such as you), you can put whatever you want as that tagline (i.e. 'dune-demon', or 'mud-hawg', or whatever...) to replace the FTE tag (or you can choose to keep it).
I'm not sure what the 'numbers' are.....but 'new user' is under 25, i think.....'junior user' is 25 to 100......'senior user' is over 100 and under 500......After that I forget....
So in the year you have been active you have posted 11K times and recieved 1700 + or - reps.
I know you addressed this to 'the brick'....but if I may.....
He received 1700+ rep POINTS.......Not 1700 reps......
Some users, based on seniority (posts), or rep-level, whatever, can give another member more than one point (2, or 3, or 4.....or higher)......The admins give about 25 points every time they touch you with the wand, and the Grand Poo-bah, FTE-Ken, gives you 50 'hit points' (any D&D fans here?...) when you get smacked by him......Hopefully with a 'positive' rep.
What about the coment when you put the curser on the green boxes of another user. Is that in line with how many reps you have also. I have seen some with the same number boxes and different sayings.
The comment you are referring to changes when you are halfway to the next green box.
No wonder you have so many chicklets in your corner. I've been here for a while longer and didn't know all that, but then again, there's a lot of stuff I don't know. Don't believe me? Just ask.
Gosh, I am humbled to be in the presence of a spectacular reputation and two brillant futures. I bow down now.
Be content to be considered 'Great'......After all, you've got 'Peter the Great', and 'Catherine the Great', and the 'Great Pumpkin'.....You're in 'great' company......
