Aerostar Ford Aerostar
clockspring gone bad
Old Aug 21, 2008 | 11:16 PM
Klau's Avatar
Klau
AARRRGGHH!
I'm STUCK. I'm trying to replace my clock spring....I have the air bag out and all plugs disconnected. The last step attempted was steering wheel removal. I got a universal puller from Autozone that is suppose to fit my 1994 Aerostar, but the bolts that go into the face plate are too long (puller is fully extended before engaging wheel). No problem...I had some shorter bolts. However when I started the pulling process again, I striped out one of the bolt holes...it has absolutly no threads. So what would you do now? Its a long story but I think I also stripped the first few threads where the main bolt fastens the steering wheel back on again. The central pully bolt mashed it in a bit. Yikes. Anyone have a suggestion what to do next?
Old Aug 22, 2008 | 12:58 AM
xlt4wd90's Avatar
xlt4wd90
I've almost never used pullers to pull steering wheels. The typical trick is to shock it off. When you loosen the center nut, turn it out so that its top is about level with the tip of the shaft. Then, while pulling on part of the steering wheel, hit the nut/shaft end with a hammer. You should strike it as directly and hard as possible. The nut in that position makes for a bigger target. The wheel should pop off with a good hit.
Old Aug 22, 2008 | 01:49 AM
96_4wdr's Avatar
96_4wdr
get a thread tap for the bolt hole. may have to go to the next larger size of bolt. metrics usually have a size inbetween US sizes.
get a thread chaser or die that will fit the steering wheel stem threads.
use a large brass, hard plastic or hard rubber hammer to try the shock tech.
believe all the steering wheel bolt holes on mine are stripped out and resized after 2 clock spring replacements over the past 12 years.
Harbor Freight is a good low cost place for one time use tools for the Aero
wait until you have to try and remove some of the underbody bolts
Old Aug 22, 2008 | 07:01 PM
Klau's Avatar
Klau
Got'er done
Thanks for the post, I tapped the steering wheel bolts and whacked the center bolt a few times and got the wheel off. Only took one extra trip to the parts store, so I guess thats a success! The rest of the clockspring replacement was easy as pie.
I'm replacing the flex pipe and those bolts where impossible. I had to heat with torch and cool rapidly, apply WD, hammer several times, all to no avail. Finally wrenched so hard out of frustration that the bolt just snapped. I was encouraged so I wrenched hard on the other bolt and it snapped off too. Whatever works, right!
So, off to the parts store to get two new (stainless steel) bolts....
Old Aug 24, 2008 | 11:34 AM
bozzzz94's Avatar
bozzzz94
Klau-Don't ever use the bolt type steering wheel remover tool. The newer vehicles like ours-the metal is pot metal/cold metal, like what they used to make 1960's grills out of and they strip out almost every time.
What to use then? Simple. 2 armed gear puller(with feet). At the 12 O'clock position simply trim about a quarter inch of the plastic trim away just enough to put the foot over the flange. This will allow you to place the arms at 12 and then 6 O'clock. A couple of turns-PRESTO-wheel comes off in a controlled environment.
Sounds like you placed it back on successfully GREAT. There might be another time or another Aero so I was just sharing what I do. The hit and shock method works perfectly. The only problem is that if you miss your mark it could create a stress crack along the tightening area of the center. You wouldn't want anything going wrong at 70 MPH.
As an added measure-I always draw a match mark on the nut of something I've loosened up. Always after you've just had something removed you should go back and re-tighten or make sure it has loosened up.
Old Aug 25, 2008 | 07:45 AM
Torsen Rick's Avatar
Torsen Rick
I did it similar to how bozzz described. In my case, I was trying to install a leather-wrapped wheel from an earlier van in place of my stock plastic one.
Old Aug 25, 2008 | 07:46 PM
rebocardo's Avatar
rebocardo
#5 bet me to it. FWiW: Try a little PB Blaster or Rust Reaper on the wheel. WD-40 is useless for most things.
Old Oct 19, 2008 | 07:10 PM
Modman_4's Avatar
Modman_4
Here's what I did when I replaced my clockspring. I too bought a puller, and I also visited my local U-Pull-It junkyard. I took my trusty Aerostar repair manual and a smattering of tools, and practised my butt off on a series of junked Aerostars first, until I was pretty good at the whole routine of swapping out the clockspring. In the process I also was able to assemble a toolkit of just the essentials, which came in handy when I revisited the junkyard for more practise!
Then I ordered a factory replacement part (new) from a Ford dealer in Georgia online, and effected the swap flawlessly, and believe me I am no mechanic but it was fun and satisfying! This cured an airbag trouble code, horn failure and cruise control failure all in one swell foop!
Old Oct 19, 2008 | 07:14 PM
Modman_4's Avatar
Modman_4
addendum -- the puller I use is a bolt type puller with a small yet thick body, and it came with two sets of bolts, the shorter ones of which worked just fine. My Aerostar is a 1992 XLT extended with the 4L, digital dash and lots of other goodies!
Old Oct 19, 2008 | 10:50 PM
bozzzz94's Avatar
bozzzz94
PS----Don't forget to "CLOCK" your steering nut. Match mark the bolt head with the steering wheel and then go back in a couple of weeks to make sure it hasn't loosened up. You did torque the bolt right?
Knewstroke97
Jan 15, 2015 11:06 AM
llacours
Aug 21, 2013 06:36 AM
hoagie48
May 7, 2013 07:11 AM
Witty73
Apr 16, 2010 06:27 AM
John7894
Feb 10, 2005 10:03 PM
