Sponsored by: Real Truck
What does engine size mean?
Old Aug 21, 2008 | 09:18 PM
FordGuy0131's Avatar
FordGuy0131
Question What does engine size mean?
Hey guys,
What does the engine size refer to? For example, 6.0L PSD engine. What is 6.0 referring to? I know that the bigger the number the bigger the engine, but what is it exactly?
Thanks in advance
Old Aug 21, 2008 | 09:25 PM
TractorM3's Avatar
TractorM3
It is the total amount of volume displaced by the clyenders. If it is in the form of 6.0, 5.4, 4.9, 5.0 the displacement (volume) is in liters. so your 6.0 you mentioned has a total cylender volume of 6 metric liters. The more diplacment you have, USUALLY means more power but not always
Old Aug 21, 2008 | 10:21 PM
Monsta's Avatar
Monsta
Sit. Stay.
Correctimundo!
If you were to take the 6.0L and put all the pistons all the way down, it would take 3 2-liter bottles of Coke to fill all the cylinders to the top.
Old Aug 22, 2008 | 01:46 AM
labrown's Avatar
labrown
It is not the volume the cylinders will hold.
It is the volume that is swept as the pistons are moved from top dead center to bottom dead center for one complete cycle of the engine. It does not include the volume above the pistons at top dead center. Only the swept area of the pistons.
Old Aug 22, 2008 | 01:52 AM
aldridgec's Avatar
aldridgec
Small technicality but in this case right. It is the amount of volume that the engine will displace, or move, internally in one revolution.
Old Aug 22, 2008 | 01:56 AM
fivonut's Avatar
fivonut
I see your point and you're correct. The formula for displacement is based (partially) on the stroke of the engine not volume of the cylinder. You can lengthen the stroke, adding displacement, and never change the cylinder volume in the block itself.
Old Aug 22, 2008 | 01:58 AM
fivonut's Avatar
fivonut
Originally Posted by Monsta
Correctimundo!
Using this example it would take 3 2 liter bottles to fill the area of the cylinder from bottom dead center to top dead center of the piston travel.
Old Aug 22, 2008 | 02:50 AM
Monsta's Avatar
Monsta
Sit. Stay.
I know that but my example for was simplicity due to nature of the question. If the OP isn't sure about what engine size means maybe explaining it with terms such as "bottom dead center" might have made the explaination more confusing.
Old Aug 22, 2008 | 06:51 AM
Dukernc's Avatar
Dukernc
Fordguy0131,
Here's a little more detail if your interested. Engine size 101.
Engine Size 101: What Does it Mean? - What Should I Know About Engine Size? - Epinions.com
Old Aug 22, 2008 | 07:24 AM
I.B. Washincars's Avatar
I.B. Washincars
Correctimundo!
I agree with this explanation. It couldn't be any simpler or more correct.
Old Aug 22, 2008 | 09:53 AM
thedaddycat's Avatar
thedaddycat
That's kind of misleading, depending on how you define cylinder volume. If you mean the total volume of an empty cylinder from the bottom of the bore in the block then yes it's true. By "stroking" an engine (lengthening the crankshaft throw) the piston will travel lower down and higher up in the bore, giving more volume at the bottom of the stroke and more compression at the top (given the same heads and gaskets).
There are terms used to describe the relationship between bore diameter and stroke length in an engine. If the bore diameter is bigger than the stroke length the engine is called "Oversquare" and if the stroke length is longer than the bore diameter it is called "Undersquare".
For most engines, stroking means having to replace the crankshaft. Due to the design of a Harley engine with its "Fork and Knife" rods that ride on a common crankpin, you replace the flywheels...
Old Aug 22, 2008 | 11:39 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
To be totally exact, figure cylinder area (PI*(r^2)) or in English "PI R squared", multiple by the stroke, and then multiply by the number of cylinders.
I still like Monsta's explanation though
Old Aug 22, 2008 | 11:51 AM
FordGuy0131
Best way to put it
Correctimundo!
Thanks! When you describe it like that, it makes it much easier to comprehend.
Thanks again
Old Aug 22, 2008 | 11:52 AM
yukondiesel's Avatar
yukondiesel
If I remember correctly...I L~120 cu in
I Litre is approximately equal to 120 cubic inches
Old Aug 22, 2008 | 11:57 AM
Ace!'s Avatar
Ace!
Also, just for reference you can multiply the liters by *roughly* 60 to get the cubic inches. So, a 6.0 is roughly a 360. Ford and Chevy's 302 and 305 are *about* a 5.0L in case you're more of a cubic inch kind of person and don't know how it relates to metric.
