A/C wont blow cold
Old Aug 21, 2008 | 06:59 PM
nitronigs's Avatar
nitronigs
A/C wont blow cold
Hi,
I have a 1977 Ford LTD with a 351 my problem is after i charged my system with R-12, my compressor is engaged and the lines are frosted up everything seems normal but it still wont blow cold i even looped my heater hoses to eliminate that out of the equation.The heater controls seem to be working properly if anyone has any solutions as to why i am not getting any cold air please post........Thanks Jeff
Old Aug 22, 2008 | 07:32 AM
projectSHO89's Avatar
projectSHO89
What are your low and high side pressures?
What are the temps of the evaporator inlet and outlet?
Steve
Old Aug 22, 2008 | 10:11 AM
Holmesuser01's Avatar
Holmesuser01
If your lines are frosted, you probably are undercharged and your evap coil is frozen.
Have you pulled the blower to be sure the fan and evap are clean and free of leaves?
Old Aug 22, 2008 | 09:10 PM
nitronigs's Avatar
nitronigs
I believe the low side was 35 psi which was the standard according to the kit i purchased.i havent really torn anything apart before i got some general ideas of what might be the problem.The kit i used to refill my a/c R-12 is Red Tek 12a this product was recommended to me by a shop in town.What is the easiest way of getting at the blower fan to see if it is plugged of debris?.........thank you
Old Sep 2, 2008 | 01:05 PM
52 F3's Avatar
52 F3
I believe the system you have has a POA valve and there is a port for a pressure reading on the POA valve besides high and low pressures. You can have the correct charge and still not have cold air because of the POA.
Sorry. I'm not familiar enough with this system to help you trouble shoot it.
I just know it is a different system. Maybe someone will come along with more info.
The blower fan is accessed under the dash behind the glove box. Not to tough to remove if you are limber enough to work upside down under there.
Richard
Old Sep 2, 2008 | 01:15 PM
nitronigs's Avatar
nitronigs
Ok thanks Richard hopefully someone will have more info into this matter.......
CGarten
General Automotive Discussion
Mar 27, 2013 10:29 AM
paulaconroy
1997 - 2003 F150
Nov 17, 2009 07:17 AM
bmxerbrett
Jan 9, 2006 12:01 PM
toots
Apr 20, 2005 04:54 PM
LakeSnake
1997 - 2003 F150
Dec 15, 2004 03:29 PM
