Sponsored by: Auxito
Heater blowing cold air
Old Nov 16, 2009 | 05:18 PM
paulaconroy's Avatar
paulaconroy
My 03 Ford F150 started blowing cold air out of heater this am. Any ideas of what might be wrong?
Old Nov 16, 2009 | 05:27 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
If it always blows cold air irregardless of engine speed it could be the blend door. I would also check your **** that controls the heat and see if it is ok if you have one. This forum has a lot of info about the heating and cooling of your truck: https://www.ford-trucks.com/forums/7...xpedition.html
Old Nov 16, 2009 | 05:47 PM
paulaconroy
ok thank you. shoot, i was hoping it would be something easy.
Old Nov 16, 2009 | 06:06 PM
n5926g's Avatar
n5926g
It could be the air blend door,or the actuator...Hopefully(for your sake) its the actuator...The actuator is about the size of a pack of smokes,and has a motor,and small circuit board in it,its relatively easy to get to,and replace.....If its the door,its MUCH more of a bugger to fix.The actuator can be found directly behind the lower center dash panel cover(it goes from the lower side of the dash to the floorboard.If memory serves,the lower panel mentioned above has one plastic screw clip on each side
Old Nov 16, 2009 | 06:25 PM
paulaconroy
oh boy! i will go and see if i can find this actuator. thank you
Old Nov 17, 2009 | 07:17 AM
Joe Finn's Avatar
Joe Finn
It might very well be easy. Try swapping the temp **** with one of the other two. They often crack internally.
velocicurtis
2004 - 2008 F150
Jul 17, 2014 10:39 PM
cooter05
Feb 26, 2014 11:13 PM
doormansamaniego
Feb 11, 2011 06:47 PM
bblaylock
Feb 3, 2010 10:32 PM
arieldg
Oct 14, 2009 01:07 PM
