I'm having heating problems with my 2007 F150 King Ranch. It has the 5.4 motor. The heater won't heat up when driving, but when sitting the heater functions normally. The temp gauge stays normal the whole time. Both hoses to the heater core seem warm/hot to the touch and I can change the temp to cold/ac and it blows cold air. Is this indicative of a thermostat issue or is there something else it could be?
The thermostat is likely stuck open. Most Fords with gauges since the mid 90s have used switches instead of actual sending units, making the gauge more like an analog idiot light, hence the "normal" gauge reading.
Get a laser thermometer and measure the temperature of the water outlet on the engine.
I'll keep you posted, I'm going to switch out the thermostat and go from there. Hopefully that solves the problem, don't really want to mess with the blend door, sounds like that might be a real project.
Doesnt sound like thermostat. The idiot gauge thing only applies to oil pressure. JWA has it right, its more like the doors that control airflow over the heater core. This can be moderate or hard to repair, depending upon how much of the dash has to come apart. These systems used to be cable or vacuum actuated, probably electric on a modern vehicle, so the control switch may also be the problem.
If the blend door was the issue, it wouldn't change between being parked and going down the road. My Explorer has a bad blend door actuator, and I get max heat any time the system is on (except max a/c since that shuts off coolant flow) regardless of speed.
The fact that the temp gauge doesnt move points to air or coolant flow within the heating system. Depending upon what position the air control door(s) are stuck could result in strange behavior.
