Duraspark II
Old Sep 10, 2001 | 11:48 AM
odie1's Avatar
odie1
Duraspark II
My engine stalls while decelerating It was suggested to me that the centifugal advance isn't returning all of the way and throwing off my timing. When I took off the stator assembly, I found that most of the play (~3/16") was in the shaft itself. How much play (if any) can be expected in the shaft? Could this cause a stall ?
Old Sep 12, 2001 | 09:03 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Duraspark II
Odie1, I don't think your stalling is an ignition problem. I would look at the carburator (if you have one, you didn't mention the year). Try adjusting the idle mixture screws along with the idle speed screw, and see if this helps.
Old Sep 15, 2001 | 01:58 PM
logan_85's Avatar
logan_85
Duraspark II
ugh3012
Dec 19, 2016 10:16 AM
homertwo
Nov 3, 2016 10:57 PM
Low 150
Jul 11, 2015 12:24 PM
Gatordog
Jun 22, 2015 05:55 AM
tshrager
17
Feb 26, 2013 09:29 PM
