edge product more than likely. I have one too. Its a piece of junk, only slightly better than superchips. If I were you, I would sell it on ebay and put it torwards a TW or a DP chip. Thats what I am going to do this tuesday..
RJ45....someone had to have added that, it's not OEM
Is that RJ45 looking thing the one just left of the ash-tray? It does look like a RJ45 connector but I think that is what holds the wire that has to be grounded to reprogram the spedo, or reprogram something.
The PSOM wire to recalibrate the speedometer is a single wire connector just below the glove box door and it's marked PSOM
Our OBD port looks just like any '96-up OBD-II connector. Eight across by two down, wider at the top than the bottom. There's also a three-pin connector with rather round male pins in a "molex" connector, further forward closer to the firewall. And then, no kidding, an RJ45, looks just like an Ethernet port. Black plastic housing. I haven't looked for the PSOM on the far right.
I'm not looking for a chip or a tuner (well, not yet anyway...). I'm just looking for a way to read PCM trouble codes, possibly read ABS / air bag trouble codes, and view real time data (fuel flow in GPH, engine temp, oil temp, pressure, etc) from the sensors. Something like a ScanGauge II for '96-up passenger cars. I see Tony has his "SCT Live Wire" product (eek, spendy!), but it's only for '96-up.
Is 1995 perchance a "red-headed stepchild" year, not OBD-I, but not fully OBD-II compatible?
