Timing and injector questions
Old Aug 18, 2008 | 11:10 PM
dieselutheran21's Avatar
dieselutheran21
Wink Timing and injector questions
First: Thank you everyone who helped me get my truck running, I was able to use it to tow my car and all my earthly crap from California to Wyoming. I ended up replacing the radiator along the way, but we made it eventually.
Next question: I have just replaced the injectors with some reman ones from an ebay seller. The injectors I took out were stamped with a "B" on them, while the ones I put in were stamped with "BB". I have been searching the forum and can find no difinitive answer as to the difference between these codes (everyone is concerned with E injectors and much newer trucks!)
Last question: I am about to take the truck in and have the timing set professionally. I will be spending the next year at 7000 ft. elevation, and am wondering if the IP should be set farther advanced due to the higher elevation (a la gasoline engines - 1 deg adv for every 1000 ft over 3000 ft). I want to make sure I ask for the right thing at the shop.
Thanks again.
Old Aug 19, 2008 | 09:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually the high altitude pumps should be set with the timing a bit more retarded.
Old Aug 19, 2008 | 10:53 PM
dieselutheran21
I am bringing the truck from California to Colorado, roughly 600 ft elevation to about 7000 ft elevation. Would it help to know the #'s on the side of my pump to figure out how to make the truck run better. I'd like to get up to highway speeds in minutes instead of eventually. I'm not looking to smoke tires, but having antelope pass me on the highway is kinda embarrassing.
Old Aug 21, 2008 | 09:41 PM
Dave Sponaugle
Fact of life is a NA motor at higher elevations will suffer in the performance department.
Less air available to burn the fuel.
A ram air setup will help, a turbo would make it run better at 7000 feet than it does at 600 feet now.
cysneed
Dec 17, 2014 07:42 AM
newr
Oct 7, 2007 10:07 PM
jorlee
General Diesel Discussion
Jan 22, 2007 08:02 PM
Americun
Oct 10, 2006 09:21 AM
