4r100 experts, essential tools?
Old Aug 18, 2008 | 11:12 AM
clux's Avatar
clux
For those who have been inside the 4r100, are the Rotunda essential tools the same as needed to rebuild the e4od?
I have the Rotunda tkit for the e4od from rebuilding the transmission in my Bronco, If the same tools apply to the 4r100 I'll keep them, if not they're going on e-bay.
Old Aug 18, 2008 | 04:52 PM
mueckster's Avatar
mueckster
They are pretty much the same basic trans. Most of the specialty tools would be the same. I fabricated all of mine that I used. I don't have any of the Rotunda tools. I would keep them since you already hav'em. PM me, if you decide you want to part with'em.
Old Aug 18, 2008 | 10:31 PM
clux's Avatar
clux
That's what I understand, and I can't find anything about a kit with the clutch compressors, etc. for the 4r100 so I think these are the ones.
Old Aug 18, 2008 | 10:56 PM
mueckster's Avatar
mueckster
Far as I know, all the clutch compressing tools are the same. The passages in the case and the center support bearing are the two main differences that I can think of. But, these do no not require any different tools for the rebuild. I compared the two transmissions in my rebuilding manuals when I did mine. The rebuilding process is very similar. If you did your E4OD, then you would have no problem with the 4R100. I did use the increased count clutch packs from Alto in mine.
Old Aug 19, 2008 | 05:39 PM
clux's Avatar
clux
Cool. I've been thinking if I could find a cheap used 4r100 I would start building a replacement for my 7.3. Even though is runs good, at 235,000 miles I suppose replacement is coming sooner rather than later. Thanks for the info.
Old Aug 19, 2008 | 06:31 PM
mueckster's Avatar
mueckster
I found out about a few upgrades, after my rebuild, that I would do next time. Hopefully, that would be a long time from now. I have 12,000 miles on the rebuild with no problems. Knock on wood. This was my first automatic rebuild. I figured if I could do this one, I wouldn't be afraid to tackle another. It was a good learning experience.
Old Aug 19, 2008 | 10:23 PM
cangim's Avatar
cangim
Well I have nothing new to add that Roland hasn't already stated. I would definately rebuild mine again if the need should arise. Keep the tools, you'll be glad you did.
jerrytown2001
16
Dec 27, 2019 05:24 PM
John Clugston
Aug 11, 2016 10:41 AM
02sd
Sep 17, 2014 09:00 PM
muckypaws
1978 - 1996 Big Bronco
Mar 27, 2007 10:19 AM
camarokid81
Oct 5, 2004 12:17 AM
