Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
DIY arc starter?
Old Sep 15, 2003 | 12:57 AM
Stagecraft Chris's Avatar
Stagecraft Chris
DIY arc starter?
Anyone out there ever built an arc start for their buzz box? I'm thinking about converting my buzzbox into a TIG.
I've figured out how to build the power controller but I'm kinda stuck on the arc starter. I was thinking about using a old coil driven with a horizontal output transistor out of a TV. Has anyone actually done this?
Chris
Old Sep 16, 2003 | 09:58 AM
Mike W's Avatar
Mike W
DIY arc starter?
Shop around for a used high frequency box. I bought a Lincoln HF unit years ago. It is basically a spark gap radio transmitter. It is simple but would not be easy to duplicate.
Old Sep 16, 2003 | 10:05 PM
Stagecraft Chris
DIY arc starter?
I would buy a HF unit but that takes all the fun out of it! I was thinking about building an arc-gap setup but I thought: "Wait a minutes, I have transistors and I know how to use them!" Who knows... Maybe I'll try to build something over Christmas.
Old Sep 17, 2003 | 05:30 AM
Torque1st's Avatar
Torque1st
Posting Legend
DIY arc starter?
Could you just grab the entire HV unit out of a TV and modify it a little?
Old Sep 17, 2003 | 12:54 PM
Mike W's Avatar
Mike W
DIY arc starter?
Maybe but you might fry yourself. If I recall correctly, the HF was designed to flow on the surface of your skin should you touch it. RF travels on the outer layer of a conductor rather then throughout it.
Old Sep 17, 2003 | 02:14 PM
Stagecraft Chris
DIY arc starter?
The reason I can't really recycle the HV unit out of a TV is twofold. First is it's setup to run at a lower frequency (55kHz vs 200-300kHz for an HF unit) and second, most TV flybacks have a diode built into the coil that makes it hard to couple the HV into the welder handly.
And yes, HF will flow along the surface of your skin, especially at higher (<100kHz iirc.) It can also give you RF burns. But that's what welding gloves are for.
Old Oct 7, 2003 | 08:29 PM
monckywrench's Avatar
monckywrench
Got any oil burner ignition transformers? That might do the trick.
Old Oct 24, 2003 | 12:30 PM
86turbodsl's Avatar
86turbodsl
www.diywelder.com
Common topic. Ask there. Lots of guys have done this.
Get on the mailing list.
travisb6989
1997 - 2003 F150
18
May 17, 2014 09:46 AM
MountaineerWV
Electrical Systems/Wiring
18
Dec 21, 2013 03:00 PM
fordtough732487
44
Sep 25, 2012 02:00 PM
Prairie Lariat
18
Oct 24, 2009 03:07 PM
EMB135Driver
2004 - 2008 F150
Jan 7, 2007 10:54 AM
