New Fuel Pump
Old Nov 9, 2008 | 09:41 AM
OUTPLAYN's Avatar
OUTPLAYN
Originally Posted by PaysonPSD
I felt that my truck was not getting enough fuel at the high end of WOT runs. I wanted to replace the fuel pump. After reading this post (LINK) by Curtis (Pocket) I decided to go with a Walbro GSL 392. Thank you Curtis for posting your findings and install tips. You saved my non-mechanical brain a lot of guess work.
I found the pump on Ebay for $118.99 with free shipping (LINK). Very fast shipping from this seller. Ordered on Friday and received on Monday.
The SOTP meter said there was an improvement. I don't have an in-cab fuel pressure gauge so I do not know what the WOT pressure was. Here are the static fuel pressure and boost readings before and after the new pump.
Stock Fuel Pump:
KOEO fuel pressure 61 PSI (I had previously shimmed the FPR)
WOT Test:
20 PSI max boost with red line connected
22 PSI max boost with red line disconnected
With Walbro GSL 392 Fuel Pump:
KOEO fuel pressure 72 PSI
WOT Test:
22 PSI max boost with red line connected
26 PSI max boost with red line disconnected
Both WOT Tests were up the same 4% grade in 80E.
I didn't do a detailed write-up because it is pretty straight forward, but here's a LINK with pics and tips on install. .
FYI - Still running stock sticks, stock turbo and stock 15° HPOP
OK...I have to ask the simple dumb uestio of the day. Where did you get that filter?
Tugly
117
Jan 23, 2016 11:35 PM
DIYiT
Mar 5, 2013 11:57 AM
superduty4x4
25
Aug 2, 2011 09:18 PM
PaysonPSD
96
Nov 16, 2010 03:45 PM
John7894
Aug 6, 2010 11:26 AM
