Sponsored by: Real Truck
4x4 troubles
Old Aug 11, 2008 | 11:23 AM
06silvercrew's Avatar
06silvercrew
4x4 troubles
My 06 psd F250 with ESOF 4x4 wont engage. Its got a code in the 4x4 module C1728. I can watch the input from the switch with my scan tool and the switch is commanding it how it should. I've checked all circuits from the module to the motor on the x-fer case and all test fine. I havent had much time to dig too deeply on it, has anyone had this problem? Im leaning towards the motor being bad, just getting some input if anyone has any. Thanks,
Scott
Old Aug 11, 2008 | 12:21 PM
ReAX's Avatar
ReAX
Are you sure it's the xcase and not the hubs?
Old Aug 11, 2008 | 12:33 PM
rugermack's Avatar
rugermack
Try manually locking the hubs.
Old Aug 11, 2008 | 02:23 PM
06silvercrew
No guys, its a problem with the transfer case engaging. Nothing to do with the front end whatsoever. It has the code C1728 which is for x-case not shifting between ranges. I have 2-hi and nothing else. The front driveshaft wont spin.
Old Aug 11, 2008 | 02:51 PM
rugermack's Avatar
rugermack
I haven't had any problems with the shift motor yet, but with 160k, it shouldn't be too far away.
Old Aug 11, 2008 | 07:15 PM
dchamberlain's Avatar
dchamberlain
With the key on and the engine off, transmission in neutral (or foot on clutch) switch from 2H to 4H. You should be able to hear the shift motor attempting to shift.
Obviously you need the window down and be in a quiet area.
Old Aug 11, 2008 | 07:21 PM
ReAX's Avatar
ReAX
Probe the motors wires, if they show power but the motor doesn't move, you've got a dead motor. You could also check for amperage, but if the motor is stalled it will probably trip a 10amp fuse pretty easy.
Old Aug 12, 2008 | 10:54 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check the wiring to the switch - the servo motor assembly has a switch on it that tells the GEM (or whatever they call it now) what gear the transfer case is in.
If the servo is actually shifting, the switch will tell the GEM it's in 4x4 - if it never sees it shift (by watching the switch) it might shift back just to be safe.
First thing, check if the servo motor is running as has already been mentioned.
1918ALF
Mar 6, 2015 09:47 PM
jlb911c
1978 - 1996 Big Bronco
Feb 23, 2015 08:14 AM
ScottyScott70
New Member Introductions
May 22, 2014 11:26 AM
sunnybottomboys.de
22
Apr 5, 2012 03:45 PM
bulletpruf
Aug 25, 2011 06:52 PM
