6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turbo surge?
Old Aug 9, 2008 | 08:28 PM
sturzinator's Avatar
sturzinator
turbo surge?
Coming home tonight, windows down, up a 3% grade around 40 miles an hour with no load I heard the turbo surging. Looked at the turbo boost gauge and, sure enough, it would spool up to around 10psi and let off to about 3psi. It wasn't really fast, just about a second to spool and then it would drop. I wasn't moving the throttle at all. Never heard it do that before. I had a 7.3 that did it so I know what surge sounds like.
Regen cyle? EGR valve? I'm stumped...
Truck is a Job #3 with 2500 miles on it.
Old Aug 10, 2008 | 04:28 PM
sledhead_24_7's Avatar
sledhead_24_7
sounds like it more than likely went into a active regen cycle on you. mine does that every time it goes into regen, which happens to be about every 100 miles or so for the past 32,000 miles. pretty easy to tell when in regen because of the boost gauge bouncing all over the place and making odd whistling and hissing sounds.
Old Aug 11, 2008 | 12:40 AM
SANDDEMON08's Avatar
SANDDEMON08
I thought the same thing but the boost will still go to 20 PSI in regen.
Old Aug 11, 2008 | 01:34 PM
sturzinator
Time for a chip then... I'm about over the whole regen thing anyway.
Old Aug 11, 2008 | 02:01 PM
SANDDEMON08
Update, i had the stock tune in and the turbo surged just like you stated and it was in regen, if you press the instrument cluster an go to system check it will tell you if the truck is in a exhaust cleaning cycle if you have the updated software in the truck.
Old Aug 11, 2008 | 02:06 PM
sturzinator
Thanks for the update, SANDEMON08. BTW where do you have your Dash Daq mounted? I'm really considering Spartan tunes, but have no idea where to put the DD.
Old Aug 11, 2008 | 02:10 PM
SANDDEMON08
I mounted mine in the lower right side of the windsheild close to the grab handel.
Old Aug 11, 2008 | 02:12 PM
SANDDEMON08
I take it down in the afternoon if the truck is sitting for awhile, the sceen got hot once and discolored, nothing permanent but im a little more carefull now. The temps in the truck can get to over 140 degrees around here in the summer.
Kert0307
Jul 28, 2015 10:08 PM
nicksorenson
Jul 30, 2014 07:57 AM
Liquid10Rider
39
Jun 10, 2013 10:47 AM
Amilledge8
Feb 25, 2012 05:47 PM
