Third member swap question
Old Aug 8, 2008 | 03:17 AM
SRT77's Avatar
SRT77
Can you swap in a third member from any year, provided of course the spline count is the same? I am hoping to go to the junkyard and find a lower geared replacement and just need to know if I can look at the 80's model trucks also.
I currently have 2.75 gears in my 77 f150 2WD and recently shoved 33's under it so I"m looking to lower the ratio a bit.
Thanks for any info
Old Aug 8, 2008 | 10:26 AM
Pickupmanx2's Avatar
Pickupmanx2
Yep, pretty much! That is the handy part of them, not sure when Ford went to the 8.8", maybe those were in the rangers only, but the 9" are plentiful. Easy to pull also.
how about this,,,,
http://fresno.craigslist.org/pts/787785988.html
Old Aug 8, 2008 | 11:23 AM
1985 Ford F-150's Avatar
1985 Ford F-150
8.8 statred in the 80s. I just swapped a 77 9inch into an 85 I figured it was easier to just do the whole thing rather than the third member. The only thing was the yokes were different and the brake lines on the 80s ones were metric.
Old Aug 8, 2008 | 12:14 PM
hairyboxnoogle's Avatar
hairyboxnoogle
As far as a 9" and 8.8 goes im 99% sure theyre all the same. The Dana's may be different tho
Old Aug 8, 2008 | 12:24 PM
1985 Ford F-150
No 8.8 has a cover in the rear and a 9 inch dont. It also doesnt have a third member like the 9 inch its more like a dana rear. The 8.8 does not have a third member it has a carrier with the ring gear on it. A nine inch has the yoke, pinion and carrier all in one package that is what a third member is. They are two different beasts every 2wd ive had from the 80s has had a 8.8 and the 4x4 I have has the 9 inch.
Old Aug 8, 2008 | 10:20 PM
hairyboxnoogle
3rd member/ pumpkin... close enough to the same thing if you ask me, but to each thier own... i was merely stating that all gears should interchange with an 8.8... and all gears for a 9" should interchange. Center section or no
Old Aug 8, 2008 | 11:04 PM
85e150's Avatar
85e150
There are some 9's that are actually 9 3/8s, and those don't fit in the same housings. Buy carefully. But, yes, same spline, good to go.
Old Aug 8, 2008 | 11:42 PM
straightsix4x4's Avatar
straightsix4x4
Very good info, I got a 31 spline posi for free with the same gear ratio as my truck so I figured I'd just stick the posi member into my housing, I stuck it in there alright, about half way... after spending an hour or so getting the ring gear unstuck from my housing I went to look at the housind the posi came out of, it was originally under a bronco, it had been clearanced with a grinder, thats what I did to mine also, problem solved, works real well. would be interesting to know what that posi was in originally...
EDIT: Tracloc for all you purists...
Old Aug 12, 2008 | 03:22 AM
JimBoB77's Avatar
JimBoB77
It probably came out of a Lincoln car. They had the 9 and 3/8's.
I have several 9" rear ends and pumpkins. Some from cars some from trucks.
You mainly need to make sure if it is 28 or 31 spline axles. I have rebuilt many of them through the years. I liked the Detroit lockers the best for racing dirt track, street machines, and drag racing. Now I am 67 years old and not racing anymore, but building two trucks right now with the 9 inch rears. Both will be posi, (trac loc), and one has the stock 389 gears in the "N" pumpkin that it came with in a 75 chassis, 4x4. I don't know if it has 31 or 28 spline, but guessing it is 31 spline. I also have a couple other posi's, one will go into the street rod pickup that has an open 2:75 9" right now. It too will have the "N" case but 4:11 gears, and 28 spline axles, in a Mustang rearend.
Another good strong pumpkin is the older "war" pumpkins used in some of the 57-59 Fords, I believe, maybe some later ones. Has the extra ribs, but no "N" on it. I just have one of those at this time, hard to find.
Jim
BMW2
Aug 6, 2014 02:14 PM
Rusty_S
Feb 26, 2014 12:38 PM
austin2466
Jul 31, 2009 11:49 AM
rhetor
Jul 25, 2005 11:42 AM
SEANSTER
Apr 2, 2000 12:51 PM
