Third member swaps
Old Jul 27, 2009 | 04:24 PM
austin2466's Avatar
austin2466
Third member swaps
I have a nine inch with 28 spined axles, small bearing. Will any other nine inch third member bolt in? or does it have to be specific?
Old Jul 27, 2009 | 11:33 PM
85e150's Avatar
85e150
Has to be 9, not 9 3/8s, and has to be 28 spline.
Old Jul 28, 2009 | 12:24 PM
austin2466's Avatar
austin2466
How do I confirm that I have a 9 and not the 9 3/8ths? Measure the housing im sure, but what part? I saw a couple at the junkyard in late 70s early 80s f150's those 9 as well?
Old Jul 31, 2009 | 11:49 AM
rockher_man's Avatar
rockher_man
Lightbulb Nines...
Hey man...measure the ring-gear...
But...first...ya gotta GET to it...
Seriously...These suckers a fairly simple units...IF ya take your time!
Is this for your Effie? The "earlier" the better...overall width-wise...
Check this out from this site...
https://www.ford-trucks.com/article/idx/9/172/article/1948_through_1960_Ford_F1_and_F100_Rear_Axle_diffe rential_Swaps.html
It will be a good start......
I picked a complete 9" out of a '70 F100 (we think) and it's a perfect fit...
My girl talked the seller down to $70.00 while I was gettin' it ready
to load up!!!
11" drum brakes...BIG axle bearings...large tubes...we (and everyone)
have decided it is an "un-marked" Nodular...do NOT belive all the "stuff" ya
read about these things...
I have affectionately name this **** Franken-Nine due to all the headaches
I incurred tryin' to figure out what the he!! it is...
A 9" center section is a 9" center section is a 9" center
section is a 9" center section is a 9" center section...
The ONLY difference I found is some have a drain-plug and some do not...some fill-AND-drain-plug...weird huh...
You get the idea...
Bigbruce
Apr 16, 2017 06:01 PM
mike
1978 - 1996 Big Bronco
Jun 7, 2016 08:09 AM
Reed
Jul 16, 2013 12:14 PM
ef150owner
Mar 21, 2012 08:51 PM
jmadsen
Oct 7, 2008 10:15 AM
