This has happened twice to me in the last couple of months, 2005 f-250 6.0 the display does not come on at all until I recrank the truck? Now my brothers truck is doing it. I have had electonic problems before with a 97 f-150 and the service department told me they would have to have it hooked up to their computer when it happens. I quess what I'm asking has anybody else had this happen to them and do you know if it leaves some kind of code for the ford place to see if I bring it to them with the ac still working?
<TABLE style="WIDTH: 470pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=627 border=0 x:str><COLGROUP><COL style="WIDTH: 470pt; mso-width-source: userset; mso-width-alt: 22930" width=627><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 470pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=627 height=17>Here is some old info I kept in my spreadsheet -
A/C not Working:
</TD></TR><TR style="HEIGHT: 22.5pt" height=30><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 470pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 22.5pt; BACKGROUND-COLOR: transparent" width=627 height=30>Your head unit is starting to go south. Sometimes turning the ignition off and then back on corrects it.</TD></TR><TR style="HEIGHT: 33.75pt" height=45><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 470pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 33.75pt; BACKGROUND-COLOR: transparent" width=627 height=45>Another trick is to flip the headlamp switch from the "Off" position to the "Auto" on position. I typically leave my headlamp switch in the "Off" position, and on the rare occasions when the A/C controller appears to be "dead" after initial start-up, I flip the Headlamp switch back & forth and the A/C controller will come on.</TD></TR><TR style="HEIGHT: 33.75pt" height=45><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 470pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 33.75pt; BACKGROUND-COLOR: transparent" width=627 height=45>Very common problem. Mine did the same thing the first week I owned my truck. Turn the head lights on and off 2 times and it will come back to life. I never took mine in to get fixed and I never had problems with it other than no display once or twice a year.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 470pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=627 height=17>https://www.ford-trucks.com/forums/633549-a-c-display.html</TD></TR></TBODY></TABLE>
The head lamp trick worked on mine also. FWIW, since I got new batteries it has not happened. With the old batteries it happened about once per month. Coincidence?
Interesting...mabe the heat has got to my batteries. I'm going to take it in next week and see if ford can fix it while its still under warrenty.
