01 Ranger
Old 08-06-2008, 09:02 PM
DLRing's Avatar
DLRing
DLRing is offline
Unhappy 01 Ranger
I am new here so maybe someone can help me. I ran the code reader on my truck. The codes were PO171 and PO174. I looked it up and it says lost communtation with restraint systems b and e. I am not so sure what that means. The truck runs great. Can some one clue me in..Thanks
Old 08-06-2008, 09:52 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
PO171 and PO174 are lean codes, which means the cylinders are seeing too much air and/or not enough fuel. The most common cause of lean codes on both banks is a vacuum leak. What engine does your truck have?
Old 08-07-2008, 03:18 PM
DLRing's Avatar
DLRing
DLRing is offline
its a 4.0. It runs fine or at least feels like it. :-) Any suggestions? Thanks
Old 08-07-2008, 06:39 PM
Rockledge's Avatar
Rockledge
Seeing that it's an '01 4.0L SOHC, I have two suggestions:
1. Leaky rubber hose at the PVC valve assembly;
2. Leaky O-ring intake gaskets.
Old 08-08-2008, 10:14 AM
DLRing's Avatar
DLRing
DLRing is offline
Talking 01 Ranger
Thank you so much for your time. I will check into those things..
Old 08-08-2008, 11:31 AM
Rockledge's Avatar
Rockledge
You're welcome.
For reference, the PCV valve on your 4.0L SOHC located at the rear of the driver side valve cover, inside of the larger rubber "elbow" hose that is shown in the photo. It has a coolant heater loop around its body to prevent water from freezing and blocking the PCV system in cold climates:
Also, should you determine that the intake gaskets need replacing, then go with new Ford gaskets. They have been redesigned and are thicker and fit better.
P.S. Welcome to the site.
Old 08-10-2008, 12:09 AM
DLRing's Avatar
DLRing
DLRing is offline
OH WOW! Hey thanks...Your the bomb!!..I will take a look at that tomorrow..
wulfman
07-31-2011 06:30 AM
HSI111
17
05-12-2011 11:03 PM
mrswift
1999 to 2016 Super Duty
05-10-2010 12:44 PM
stoney720
03-25-2010 04:33 PM
bowdog
1997 - 2003 F150
02-07-2008 10:13 AM
Quick Reply: 01 Ranger
