ebp sensor codes and truck is running terrible
my wifes truck just started running bad , cel light on, codes po470,po475, po 478, p1670 po603 and p1613 or 1316 can any one help me out here . i cant afford to get shafted by dealer. it reset once and ran good but then really runs bad... any help ?
Can you expand on what you mean when you sat "running bad"?
Missing? Rough idle? No power?
Is the engine stock?
P0470 Exhaust Back Pressure Sensor Circuit Malfunction
P0478 Exhaust Pressure Control Valve High Input
P1670 EF Feedback Signal Not Detected
P0603 Internal Control Module KAM Error
P1316 Injector Circuit/IDM Codes Detected
Welcome to FTE. For future reference, we have a 7.3 diesel specific section located further down the main forum listing. Your problem is the P1316. Odds are the UVCH came loose on one side. That's your under valve cover harness.
Read this thread for instructions with pictures and a video of how to fix this yourself. https://www.ford-trucks.com/forums/8...ck-shakes.html
sharpcar
1997-2006 Expedition & Navigator
03-22-2008 09:54 PM
