Alternator Install
Old Aug 5, 2008 | 09:55 PM
yukgoon's Avatar
yukgoon
Alternator Install
Ok so I should have paid attention. I took the engine out and did not mark all the wires. I have an 82 F-100 with an I6. Its stock. Can anyone tell me which wires go to which terminal. I know I should have paid attention but I got a little carried away.
Old Aug 5, 2008 | 10:46 PM
Franklin2's Avatar
Franklin2
Do you have guages in the dash? The "F" wire will be the orange/blue, the "s" wire will be white/black, and the large output wire will be black/red. The "s" wire will be hooked up differently depending on if you have guages or not.
Old Aug 6, 2008 | 01:32 AM
alcan60283's Avatar
alcan60283
http://fordfuelinjection.com/public/...LT_wiring3.gif
Basically, the thickest wire with the large ring terminal goes on the BATT terminal, and then the remaining two wires hook to the Field and Stator terminals.
Hope that helps.
Jon
TigerRat
Feb 20, 2013 12:54 AM
jjf100
2004 - 2008 F150
May 21, 2009 08:32 AM
gumboluvr
May 28, 2007 09:04 PM
ElvishWarrior21
Bronco II
Jul 9, 2003 12:44 PM
Ford7875
Paint & Bodywork
Jan 10, 2003 06:27 PM
