Manual Trans??
Old May 28, 2007 | 07:15 PM
gumboluvr's Avatar
gumboluvr
Manual Trans??
I have read a lot of post here about trannies and should have paid more attention.....But How do I know exactly what trannie I have??
It is a 5 speed manual, also what rear end?? how do I find the info???
Old May 28, 2007 | 07:27 PM
Winger235's Avatar
Winger235
If it is the original Transmission it is a ZF-542 and the rear end tag should still be attached to the cover on the rear end.
Old May 28, 2007 | 09:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Look at the rear axle and there should be a tag under one of the bolts.
The tag will have three lines of numbers on it.
The bottom line has the ratio as the first set of numbers.
Usually the bolt head covers the first number of the ratio.
So the normal first numbers you should see are either .55 or .10 which would indicate an open 3.55 or 4.10 ratio.
If you see L55 or L10 you would have a limited slip 3.55 or 4.10 gear.
The transmission ID plate is on the drivers side about 1/2 way up the transmission and about in line with the shifter front to back.
Dutter
1983 - 2012 Ranger & B-Series
Feb 9, 2011 05:48 PM
ralf
1978 - 1996 Big Bronco
Feb 26, 2007 01:28 PM
cjben
Jan 29, 2006 01:45 PM
nick
Jul 4, 1999 12:47 PM
